BOE Robot Questions
Hi,
I received a BOE with Stamp II Chip recently. I will be making a vehicle similar to the BOE bot for a school project.
I have two questions.
1. I will be using a different brand servo (and yes it is continuous rotation)
www.lynxmotion.com/Product.aspx?productID=429&CategoryID=38
Will this servo work with the BOE and will the set-up be the same as with the boe-bot servos by futaba?
2. I have been practicing loading the code with the LED set-up on the breadboard. I noticed that the code runs from the Stamp II right after I hit RUN from the Basic stamp editor. Is there a way to send the code to the Stamp, but not execute the code until I hit the reset button on the board?
Thanks for any help in these two areas.
-OIT_GUY
Post Edited By Moderator (Chris Savage (Parallax)) : 10/13/2005 4:05:49 AM GMT
-OIT_GUY
2) On the BOE-Bot power is kept from the the Servos during download to prevent the BOE-Bot from taking off...You will have to do something similar.
BTW, I changed your subject line.· Newb with n00b question isn't likely to get many answers.·
Chris Savage
Parallax Tech Support
csavage@parallax.com
-OIT_GUY
