FTDI Chip Not Working
william chan
I finally made a USB Interface for my SX20 SS chip using the FTDI232BM chip.
I plug it in, the SX powers up from the USB 5V supply and can be programmed by the SXKey.
But nothing happens on the PC. Windows XP doesn't start saying that some new device has been connected.
I double checked all SMT connections with a magnifying glass, nothing seems to be wrong.
Now what?
Why is there no forum on the FTDI chips?
Now what?
If not, go to www.ftdi-chip.com, download and install the Windows XP·driver for the FT2332BM chip, and TEST it with a professionally designed FTDI USB·Adapter.· This will confirm that the driver was successfully installed and that your PC hardware is working as it should.
If you have already done this, have you checked the oscillator for proper operation?
Does the FTDI chip dynamically appear (graphically, of course) in your device manager window·(under ports, com and lpt) when you connect it to the USB port?
If you are still having trouble, please provide more information regarding how you determined it is not working and any other information that you can provide to give us a clue.· In this case, a schematic and a photo of your prototype would be very helpful in identifying the trouble.
John Barrowman
Engineering
I did not install the drivers b'cos I was hoping Windows will ask me for the drivers when I plug in the FTDI device.
That's how I know it is not working, b'cos Windows is silent.
Seems like the D+ and D- are not reversed....
How to check that the 6Mhz oscillator is running? My Parallax USB scope cannot go that fast....
I have also checked that power and ground is connected to the FTDI chip and it is powered.
Another question :
Does Parallax sell the solder paste that contains suspended metals for SMT oven work?
Though we use it internally, Parallax does not offer solder paste for sale.
John Barrowman
Engineering
·1+1=10
www.zeph.com/zephpaste.htm
We are very happy with one of their hot air reflow systems.
In general, if you have an off topic question, please create a new thread.
With respect to the FTDI chip, the first time I got one (USB2SER) I plugged it into my Mac to see what would happen, and just as with your experience, nothing. The drivers linked on the Parallax web site are the .exe files, (for XP?). The FTDI site www.ftdichip.com has drivers for other OS'. The Mac OS 10 installation turned out to be roundabout, involving a trip into the unix terminal application to tweak the settings., but this procedure is well documented at FTDI. It is however more roundabout than I have ever seen before for a USB device.
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 10/7/2005 10:05:10 PM GMT
Did you install an EEPROM with the FTDI Chips? If so, is it programmed? If so, what was the·PID/VID programmed into it?
Now, if you didn't install·an EEPROM, under windows XP, the default PID/VID for the device is mapped to VCP drivers,and the device should open·up as a COM port. Is is possible this happened, and you didn't notice it?
The FTDI stuff works wonderfully, but is is hard to get working the first time!
Keep us posted!
-Dan
I went to the Control Panel/System Devices / Ports and found only Com1 and Com2 (which is native) on my Win2000 machine.
So as John suggested, I went to the FTDI website and downloaded the 232BM drivers which was zipped up.
After unzipping, I found that there are no .exe files to run to install the drivers.
Seems like only the .ini file is available. That means Win2000 must detect the FTDI chip without drivers installed, then only it will install it.
Is the Parallax (Opta) scope using the same FTDI chip? I have another WinXP computer that has the Parallax scope installed.
Does this mean that the driver is already installed?
John,
Can I post the Schematic and PCB layout in ExpressPCB file format? Will you be able to view it?
Yes, the Parallax Scope uses the same FTDI chip. No, we don't have the schematic available in ExpressPCB format -- you should be able to do that for yourself with the schematic we've provided (we actually use Protel for our boards).
Jon Williams
I meant I am going to post the ExpressPCB schematics, not Parallax.
Nevermind, here it is. Can you see anything wrong with it?
detects USB<-> Serial device and asks for the driver.
I cancelled the installation and plugs in my FTDI project, NOTHING.
I opened up the Parallax scope and compared the D+ and D- continuity checks to see whether they are reversed, but they look correct.
Except that the resistance from the FTDI chip to the D+ is only 12 ohms on the Parallax scope wheares its about 22 ohms on my board. But I think that should not make any difference.
The other thing is that my 6Mhz resonator was sourced locally.
I now attach the PCB design of the project as well in ExpressPCB format.
Now what else to check?
http://www.ftdichip.com/Documents/DataSheets/ds232b17.pdf
Of particular note -- that our engineer thinks may be causing your troubles -- is the exclusion of the 1.5K resistor that connects between pin 7 (USBDP) and pin 5 (RSTOUT#) on the FTDI chip.· There are a few other things that we noticed, but JB doesn't think that they are the cause of your problems.
Jon Williams
You are a Genius !
After adding that resistor, it just works ! The Win2000 is now asking for the driver.
I will work on the serial comm next.
Thanks a lot.
Jon Williams
please let me add a general comment here:
Aftere a series of guesswork posts, Jon had an immediate hit, once after you had provided the schematic. As you can see, the more details around a problem are presented, the better and faster a solution can be found. Do you remember how this thread started?
Now what?
I think you agree with me that this is not the kind of information that really helps others helping you to solve your problem. Please don't be offended by my post - it is a well-meant message to all forum members. A detailed problem description saves all of us valuable time, including yourself because you'll get a solution faster.
Greetings from Germany,
G
I absolutely agree. More often than not, when someone has a problem, the first thing I have to do is pump them for more information about the details of the problem. When someone says, "The IDE isn't working. How do I fix it?" I pretty much have no information to try and help them. They may as well have said, "I'm thinking of a number between 1 and infinity. What is it?"
When folks have a problem with software, they need to remember to explain all the steps needed to reproduce the problem, the exact error message that comes up (word for word, not just how they remember it), the details of their hardware configuration, the operating system they are running on, and the version of the IDE as the minimum information with the question they post.
For problems with either hardware or software, people should always list all the things they have tried to figure out the problem. If they have schematics, put them in the first post with the original question. If they have a code question, post the source code.
When you're trying to help someone over the Internet, more is more when it comes to details.
Thanks, PeterM
Then i made the scand Interface, its same whit first one, but it can not function.
When i plug it in, the SX power supply up from the USB 5V and can programmed by the SXKey.
But on the computer Windows 2000 at ' Divice Manager, Universal Serial Bus controllers ' was detac
" ! USB Device " its means computer can detac the USB interface but can not function.
Then i pulg it out then pulg in the first one USB Interfsce, it function. Computer detac the USB Interface
at ' Ports(COM & LPT) ' come out "USB Serial Port" and at the ' Universal Serial Bus controllers ' come out " USB Serial Converter"...
What happen to my scand USB Interface? Its same whit the first one, but its can not use. what problem?
G
I also check all then pins of components its connect right...
can u tell me what can i do...maybe i forget do something...
Oliver Bailey
By the way if you create too many virtual com ports, FTDI has a program that will clean them out after you disconnect all FTDI based products. They offer it on their web site as a download.
