Servo not running
I have the ground to the servo connected to a pin so the stamp can trigger it.· I was told that you need to have servos powered by a seperate battery because it will use too much of the stamps power but when I use pulsout the servo will only use the same battery as the ground.· How do I fix this so it won't drain the stamps battery?
Chris Savage
Parallax Tech Support
csavage@parallax.com
If this works, would it be possible to run the servo and the stamp off of the same battery as the stamp (given that that battery could provide enough current for both)?
Thanks.
Chris Savage
