Laser detector/light receiver
Hello:
I need a laser detector that will sense a laser beam of light from 0-600 feet. I currently have one that is off the shelf manufactured by RoboTooz, but it is not as accurate as I would like it to be. So like most of you I will build·one myself that suites my needs.
Now here is the question:
Does anyone know where to get the actual electronic component that will mount to the board to·'detect' the beam of light? 3mm x 3mm·would be nice!
First, what is the wavlength of the light you want to detect? Second, What is the power of the beam itself. And lastly, What is the mode and size of the beam, Is this a semiconductor device generating the light?
You may want to consider polarization of the beam. A fresnel lens at the receiver will help.
Sofa
Chris Savage
Parallax Tech Support
csavage@parallax.com
yea the photoresistors are the way to go. that way you can use the varible resitance
of the light on a bunch of RC type of circuits.
the laser have an extremmely high light level over a long range. also the "aperture" or tubing your collecting the laser beam works even better with the light directed into a 90 degree angle that eliminates most ambient light
lasers and photoresistors real cool
japer
