Send and recieve data through the serial cable?
Hi!
I have never programmed a BS before and just got myself a BS2.
I know the serial cable is used for transfering programs to the chip, but can
it also be used for recieving and sending data?
I want my BS2 to send some data back to the computer, to give me som stat on it's progress.
Yes, the Stamp can communicate using any of its pins as a serial port, although port 16 (the dedicated programming port) has certain advantages. Start with the "What's a Microcontroller?" text and things will become a lot clearer.
Truly Understand the Fundamentals and the Path will be so much easier...
Port '16' is a pseudo-port, that tells the BS2 to use the programming port.
