Absolute Minimum Voltage — Parallax Forums
ElectronegativityElectronegativity Posts: 311
edited 2005-09-30 08:30 in General Discussion
Hello, I am thinking about a tiny coin battery powered project based on the SX20.
The data sheets mention 2.7V, but the traces of power consumption versus voltage seem to terminate around 2.2V.
How low can you go?
Also, how important is a voltage regulator?
Would it cause a problem if I ran an SX20 directly off a 3V coin battery with no intervening regulator?
I wonder if this wire is hot...
  • BeanBean Posts: 8,129
    edited 2005-09-28 02:49
    You should be able to run it off a 3V coil battery with no problem (without a regulator).
    I think 2.7V is the minimum for all conditions (temperature ect..).
    Bean.
    "SX-Video·Module" Now available from Parallax for only $28.95
    http://www.parallax.com/detail.asp?product_id=30012
    Product web site: www.sxvm.com
    Available now... SX-Video OSD module $59.95 www.sxvm.com
    "I'm a man, but I can change, if I have to, I guess"
    Red Green
  • ElectronegativityElectronegativity Posts: 311
    edited 2005-09-28 03:41
    Thanks Bean, I'll give it a shot.
  • william chanwilliam chan Posts: 1,326
    edited 2005-09-28 13:26
    You cannot use a regulator, b'cos the regulator may take up to 3mA even when the SX is asleep at a few microamps, so it defeats the prupose of sleeping.
    At 3mA regulator leakage for the 78L05 ( small ) regulator, the coin battery will finish in less than 24 hours.
    edited 2005-09-28 14:21
    William, you are correct that a linear regulator will consume a appreciable amount of current, but switching regulators can consume much less power (in the uA) though some require a minimum load by placing a 10kΩ resistor between its output and ground to keep the output from oscillating. But if he is using a 3V coin cell, no regulator is needed.
    ·1+1=10
    edited 2005-09-28 15:01
    Electronegativity,
    Just curious, what are you trying to do at sub-3V and presumably low current?
    How much current are you expecting to deliver out of the system, and for how long?
    Perhaps this is a question of "Absolute Minimum Current" conservation rather than voltage.
    I once designed a data logger around a 16F84 that·was configured in·RC oscillator
    mode running at about 10kHz ... essentially a "functioning sleep mode" (FSM)... to
    conserve power.· I don't see why something similar couldn't be applied to an SX.
    When an event occurred one of the I/O pins would switch in a parallel resistor
    to the RC oscillator increasing the speed to about 4MHz.· At this point other devices
    were powered up... ·RTC (Real Time Clock) and Memory to "log" the event.· Once
    a time stamp and·event status was logged into memory, everything would shut down
    and go back to the 10kHz FSM mode.· Battery life from a 3V lithium (CR2032) was about
    4 months.
    In order for something like a data logger to work under these conditions, we need to
    know more information about what you are trying to accomplish.
    Beau Schwabe
    IC Layout Engineer
    edited 2005-09-28 15:41
    Hi Beau,
    I am thinking of building a "Micro Simon Sez".
    It will be an SX20 mounted on one of those Sparkfun boards with blue, red, green, and yellow LEDs around it.
    The processor will generate a table of random numbers from 1 to 4 and flash the digits in progressively longer sequences.
    The user will press colored tactile switches according to their memory of the pattern.
    I want to make it as small and light as possible, which makes a 3V coin battery ideal.
    The blue and green LEDs can run off 3V, and I am going to take advantage of the voltage drop across diodes to step the voltage down for the red and yellow.
    The SX will trigger transistors to light the diodes so as to aviod sourcing too much current since each diode can draw 20 to 30 mA and I want to put 2 of each color per side.
    William: Thanks for the advice, but since it is only a toy, the user (me) will shut it off when not in use so the processor will never actually be in sleep mode.
    Post Edited (Electronegativity) : 9/28/2005 3:45:22 PM GMT
    edited 2005-09-28 17:14
    If you are running 20 to 30 mA through each diode your coin battery is not going to last very long...
    Bean.
    Red Green
    edited 2005-09-28 17:35
    Hi Bean!
    With all diodes continuously lit the battery would drain in an hour but it will be flashing them one at a time, so that's 8 hours.
    I get a little more time because nothing is lit while it's waiting for user input.
    there is also room to sacrifice some brightness for longer battery life since these are very bright LEDs (between 800 to 1500 mcd).
    I don't really know what mcd stands for, but its probably something like millicandlepower.
    edited 2005-09-28 17:57
    you are essentially correct mcd is millicandela.
    Here is an excerpt from http://www.electro-optical.com/whitepapers/candela.htm
    Definition:
    The candela is the luminous intensity, in a given direction, of a source that emits monochromatic radiation of frequency 540
    edited 2005-09-28 19:41
    Thanks for the link Paul, I was trying to recall the definition of candela on my way to work today.
    I remembered the steradian part but couldn't dredge up the 1/683 Watts.
    The inclusion of 555 nm in the definition is a bit strange though.
    It works fine for black body radiation, but technically a 632 nm HENE laser would always have zero candlepower no matter how bright the beam is!
    edited 2005-09-28 19:49
    I think the wavelength is chosen because the human eye has a different sensitivity to different frequencies, so they chose the frequency the eye is most sensitive to. I think the frequency is a normalization value and not a pure definition, so it still works for other frequencies in the spectrum. I believe the end result is that a 1 cd green LED will appear brighter than a 1 cd red LED. This is my opinion though and not based on something Ive read, outside of anectdotal accumulation of knowledge, so I could very well be wrong.
    ·1+1=10
    edited 2005-09-28 22:40
    Electronegativity,
    Do you really want the LED's to be that bright?· There are some very impressive 2mA LED's that put out lots of light.
    Anyway, there are some other ways to reduce the amount of current without any external parts, by making use of
    the internal RC oscillator settings of the SX you can have dramatic results.
    I did not have a SX20, but I did have a SX28.· The datasheet indicates that they should be the same.
    Here is the DATA I obtained by placing a 10 Ohm resistor in series with the power to the SX and measuring the voltage
    across the resistor.
    [color=black]50MHz resonator -      0.538V = 53.8mA[/color]
    [color=black]--------------------------------------[/color]
    [color=black]4Mhz internal RC -      0.068V =   6.8mA[/color]
    [color=black]1Mhz internal RC -      0.028V =   2.8mA[/color]
    [color=black]128KHz internal RC -   0.015V =   1.5mA[/color]
    [color=black] 32KHz internal RC -    0.014V =   1.3mA[/color]
    The program was just a simple program to toggle one of the I/O pins at 1/10th the clock frequency.
    Tris_A = %00000000   'Make ALL pins on PortA output   This is because we just don't want any pins to float.
    Tris_B = %00000000   'Make ALL pins on PortB output   Floating pins EAT current.
    Tris_C = %00000000   'Make ALL pins on PortC output
    Asm
    Main:
         MOV RB.0,#1     '2 Clocks
         NOP             '1 Clock
         NOP             '1 Clock
         NOP             '1 Clock     (5) Clocks "ON"
         MOV RB.0,#0     '2 Clocks
         JMP Main        '3 Clocks    (5) Clocks "OFF"
    EndAsm
    Beau Schwabe
    IC Layout Engineer
    edited 2005-09-28 23:33
    Hi Beau, thanks for the data and the method for measuring power usage.
    It will be especially useful for breadboard prototypes where the 10 ohm resistor can be easily swapped in and out.
    I'm a little confused by your example though.
    You say it will toggle one of the pins at 1/10 the clock frequency, but it looks from the code like it would actually toggle at 1/2 the clock frequency.
    Also, which 2mA LED's are you referring to?
    Post Edited (Electronegativity) : 9/28/2005 11:59:42 PM GMT
    edited 2005-09-29 02:47
    Electronegativity,
    The code is arbitrary, I just wanted something going on inside the SX.
    But it does come in handy for measuring the frequency without tapping
    off of the OSC pins. The code divides the input clock pulse by 10, because
    it takes a total of 10 clock pulses to get through the code. 5 of the clock
    pulses are spend with RB0 High and the other 5 clock pulses are spent with
    RB0 in the Low state.
    As far as the 2mA LED's let me look into that. Digikey has some, but I don't
    have any hands on experience.
    http://www.digikey.com/
    Key words "LED 2mA"
    I will try to find the manufacturer of some 2mA LED that I do have.
    Beau Schwabe
    IC Layout Engineer
    edited 2005-09-29 03:35
    CR2032 lithium coin cells are dirt cheap, and they can last a long time in a project like this with no regulator and careful use of SLEEP. At 10 microamps, say, with the game asleep (waiting for someone to pick it up and press a key to play), the CR2032 at 220 milliamp hour capacity could sit around for 22000 hours, over 900 days. (0.220 / 10E-6). Keep the flashes short and use a large capacitor across the battery to supply the surge current.
    Tracy Allen
    www.emesystems.com
    edited 2005-09-29 14:58
    Electronegativity,
    Last night it occurred to me... The 2mA LEDs that I have are about normal brightness (what I would expect on an appliance) ...
    ...BUT If I use a super bright LED and supply a minimal amount of current, it it's still going to be VERY bright. Doing just that on a
    red LED with a forward voltage of the LED measuring 1.65V (<-- Diode check on a DMM) and a fresh 9V battery measuring 9.23V ,
    I used a current limiting resistance of 2K (two 1K's in series). With only 3.79mA of current to the LED and lights out, I could see
    the projection of the LED light on the ceiling. The LED was aiming straight up from my work bench.
    I_to_LED = (Vsupply - LEDforward) / CurrentLimitResistor
    I_to_LED = (9.23V - 1.65V) / 2000Ohms
    I_to_LED = 7.58V / 2000Ohms
    I_to_LED = 3.79mA
    Beau Schwabe
    IC Layout Engineer
    edited 2005-09-29 15:21
    Just a note, then line "MOV RB.0,#1" actually assembles as "MOV RB,#1" so it affects ALL the bits of RB.
    And if you try to do it with any bit other than 0 you will get an error. "MOV RB.1,#1" gives an error.
    Bean.
    Red Green
    Post Edited (Bean (Hitt Consulting)) : 9/29/2005 3:20:14 PM GMT
    edited 2005-09-29 15:35
    That's really odd Bean.
    What if you used "SETB RB.0" instead?
    Of course you would have to add a NOP behind it in Beau's example to keep the number of clock cycles the same.
    Beau, I think I will end up doing something like that if only to equalize the (perceived) intensity of the different colored diodes.
    edited 2005-09-29 16:56
    Why don't you code like this:
    Main
    setb RB.0 ; 1 LED is on after executing this instruction (total off time: 5 cycles)
    nop ; 1
    nop ; 1
    nop ; 1
    nop ; 1
    clrb RB.0 ; 1 LED is off after executing this instruction (total on time: 5 cycles)
    nop ; 1
    jmp Main ; 3
    As power consumption is an issue, I assume that you clock the SX at a low rate. But even when you use the 32 kHz internal clock, an on/off cycle will be as short as 312.9 µs, i.e. the LED will flash at a rate of 3.2 kHz which is way too fast. Well, yes I know, Beau provided this sample code to measure the power consumption at different clock rates - it was not intended to blink LEDs.
    Nevertheless, after seeing this example an idea came up to my mind: Reducing the LED current by applying a PWM signal.
    Beau has calculated his results based upon the voltage of a fresh 9V battery. Let me re-do it just for this example based upon a 5V supply, and an LED current of 3mA:
    R = (5V - 1.65V) / 3mA = 1.12 kOhm
    Now, let's calculate the power balance:
    Total power consumption is
    5V * 3mA = 15mW
    The LED converts
    Pled = 1.65V * 3mA = 4.95mW into light and some heat, but the majority of
    Pres = (5V - 1.65V) * 3mA = 10.05mW (or 15mW - 4.95mW) is dissipated into heat by the resistor.
    Now, let's assume, you generate a square wave with a 50% duty cycle on the LED-driving output pin as long as the LED shall be on. To make it simple, you can assume that the 50% duty cycle has the same effect as reducing the supply voltage by 50%, i.e. down to 2.5V.
    The results are now as follows:
    R = (2.5V - 1.65V) / 3mA = 283.3 Ohm
    Pled = 1.65V * 3mA = 4.95mW (same as before)
    Pres = (2.5V - 1.65V) * 3mA = 2.55mW
    As you can see, this is a much better energy balance. You could even optimize it by selecting a duty-cycle of less than 50% for the output signal for lower resistor values. Nevertheless, you should keep in mind that reducing the resistor value means higher peak currents to be sourced by the output pin, which is limited to an absolute maximum of 45mA according to the SX28 datasheet.
    Greetings from Germany,
    Günther
    edited 2005-09-29 17:37
    Thanks Guenther, That's a really good piont.
    I totally overlooked the energy dissapated by the resistor.
    I was going to incorporate 4 switches that use a 10K resistor to an input pin and have the switch draw the trickle current to ground when pressed. It seems from what you wrote that this would continuously drain power by heating the resistors.
    I must admit though that I don't completely understand the second part of your post.
    If you generate a 50% duty cycle then that is the same as putting 5V through the resistor for half as much time, so why isn't the power dissapated 1/2 as much (5.025 mW)?
    Where did the extra factor of 2 come from?
    I could see if you used capacitors to smooth out the square wave that you might be able to generate an actual 2.5V supply, but it seems to me that this is a 5V supply that is on 50% of the time.
    edited 2005-09-29 17:48
    The extra factor of 2 is because the resistor is a lower value.
    The same current through half the resistance is half the power.
    Bean.
    Red Green
    Post Edited (Bean (Hitt Consulting)) : 9/29/2005 5:48:08 PM GMT
    edited 2005-09-29 17:49
    G
    edited 2005-09-29 17:53
    Beau,
    RB.0 = 1 and RB.1 = 0 will generate SETB and CLRB in SX/B.
    Just make sure the pin is setup as an output first.
    Bean.
    Red Green
    edited 2005-09-29 17:57
    Hi Bean, now I'm really confused.
    In the first part of Guenther's example the resistor os 1.12 kOhms, and in the second part it is 283.3 Ohms.
    283.3/1120 = around 1/4 the value. If you also include the fact that the current is on for 1/2 as long then the power dissapation should be 1/8 as much.
    edited 2005-09-30 04:25
    Electronegativity,
    I'm not sure that you can relate the two numbers 283.3 and 1120 the way that you are referring to them.
    ( I could be having a dense moment though)
    This ratio you see is originating from the voltage across the current limiting resistor in series with the LED.
    Across one scenario, the voltage is 3.35V while in the other circumstance the voltage is 0.85V.
    In BOTH cases the goal is to maintain 3mA across the LED.
    Let me try to put it another way...
    If there is a 100% Duty cycle we would assume 5V 100% of the time.
    If there is a 50% Duty cycle we would expect an average of 2.5V 100% of the time.
    If there is a 40% Duty cycle we would expect an average of 2V 100% of the time.
    The normal formula for determining the Current limiting resistor for a LED is:
    Rled = (Vsupply - Vled) / Iled
    If we want to include Duty cycle, the formula becomes:
    Rled = ( ( Vsupply x DutyCycle ) - Vled) / Iled
    Basically what you are comparing between 283.3 and 1120 is the Duty Cycle and the resistor
    required to maintain 3mA across the LED. See table below:
    DutyCycle    Rled
    100%        1116.7 Ohms
     90%         950   Ohms
     80%         783.3 Ohms
     70%         616.7 Ohms
     60%         450   Ohms
     50%         283.3 Ohms
     40%         116.7 Ohms
     35%          33.3 Ohms
     30%         -50   Ohms
    Note: -50 Ohms at 30% indicates a voltage less than the forward LED voltage ( LED is OFF)
    Power in all cases will be 4.95mW across the LED since we are forcing the current to be 3mA.
    Power across the Current Limit resistor will vary between 10.05mW at 100% and 0.299mW at 35%
    P = I * V
    P = I^2 * R
    For 100%...
    P = 3mA^2 * 1116.7Ohms
    P = 0.000009 * 1116.7Ohms
    P = 10.05mW
    For 35%
    P = 3mA^2 * 33.3Ohms
    P = 0.000009 * 33.3Ohms
    P = 0.299mW
    The goal here is to get as little current as possible across the resistor. Ideally, you would not even
    have a resistor, and just generate a Duty Cycle that is equal to the forward voltage drop of your LED.
    However in the real world TEMPERATURE is your enemy, and can cause the forward voltage of your
    LED to slightly increase or decrease. Having a resistor here for a little "padding" can be your friend
    in this case.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 9/30/2005 4:28:52 AM GMT
    Electronegativity,
    To calculate the resistor for the assumed 2.5V, I used this formula:
    At first glance, you might think, reducing the voltage by 50% would also require reducing the resistor by 50%. But this is not the case because the LED's forward voltage is (almost) a constant of 1.65V. Thus, the voltage across the resistor is now 2.5 - 1.65V = 0.85V which is much lower than at 5V supply: 5 - 1.65V = 3.35V. Therefore, the resulting value is less than 50%.
    Well, what if we would reduce the duty cycle to achieve an effective voltage of 1.65V? According to my formula, the resistor would be 0 Ohms in this case, i.e. no loss at all. But you should keep in mind that this would cause high peak currents to be sourced from the output, so you better use a resistor of no less than 120 Ohms. This limits the peak current to some value below 30mA which is a safe value for the SX.
    If the LEDs are still bright enough, you can try to further reduce the duty cycle down to a value that still results in an acceptable brightness (w/o further reducing the resitor value).
    Yes, you are right, in case you have connected 10kOhm pull-up resistors between the inputs and +5V, each of the resistors will dissipate 2.5 mW as long as the switches pull the inputs low. You might consider using pushbuttons instead, and handle the toggle functions by software. In this case, power is dissipated only as long as the buttons are pressed. Don't forget to de-bounce the pushbuttons. You can do this by software. For example, when you poll the button states -say - every 20ms, you accept a state change ony, when the state is still the same after the next poll.
    G
