EAGLE - GERBER file problem — Parallax Forums
SN96SN96 Posts: 318
edited 2005-09-28 14:33 in General Discussion
Hello gents,
I was reading the tutorial on the Spark Fun Electronics website on how to generate gerber files using their script files. I did as the tutorial said and all my files came out with no problems except the darn .drd file (Drill data). I was using Pentalogix's View Mate to review my output files and for some reason when I import the .drd file, it shows several small specks way way out side the boards boundry. Also there are more "specks" than there are holes in the original design.
The .drd file is using Excellon as the device. Could it be that View Mate cant read Excellon? is this normal?
I provided a screen shot to help explain my results with the drill data.
Post Edited (RoboROOKIE) : 9/27/2005 10:34:36 PM GMT
  • StarManStarMan Posts: 306
    edited 2005-09-28 01:27
    I think the Excellon file is just a text file.· I indicates the x, y locations for each drill bit.
    The board house I use also needed the .dri file so they know the drill bit sizes.
    Chris I.
  • SN96SN96 Posts: 318
    edited 2005-09-28 02:21
    Thanks StarMan!
    This has been driving me up the wall. You are right, it is a text file and I do see data in it when I open using notepad.
    I guess you can't view it in View Mate like all the other layers to see if things line up?
    Here is what is inside that .drd·file (my board is very small about 2" x 2")
    M48
    M72
    T01C0.0320
    T02C0.0400
    T03C0.1102
    T01
    X6417Y2853
    X7167Y2853
    X10917Y2853
    X11667Y2853
    X8167Y5853
    X7417Y5853
    X6292Y8853
    X9292Y8853
    X10792Y8853
    X13792Y8853
    X15792Y8353
    X15792Y5353
    T02
    X2792Y5853
    X2792Y6853
    X2792Y7853
    T03
    X2292Y2353
    X2292Y11353
    X15792Y11353
    X15792Y2353
    M30
    edited 2005-09-28 04:35
    It looks like something·has gone afoul somewhere.
    The numbers after the Xs and Ys are thousanths of an inch.· You have some numbers in the range of 15 inches.
    Here's the file from my latest board.· The board size is the default 3.4 x 4 for Eagle Lite.·
    M48
    M72
    T01C0.1260
    T02C0.0320
    T03C0.0940
    T04C0.1102
    T05C0.0276
    T06C0.0400
    T07C0.1300
    T08C0.0236
    T01
    X179Y439
    X179Y3139
    X3500Y2721
    X3879Y3139
    X3879Y439
    T02
    X3119Y2239
    X3119Y2339
    X3119Y2439
    X3119Y2539
    X2819Y2539
    X2819Y2439
    X2819Y2339
    X2819Y2239
    X1909Y2359
    X1809Y2359
    X1709Y2359
    X1609Y2359
    X1509Y2359
    X1409Y2359
    X1309Y2359
    X1209Y2359
    X1109Y2359
    X1009Y2359
    X909Y2359
    X809Y2359
    X709Y2359
    X609Y2359
    X609Y2959
    X709Y2959
    X809Y2959
    X909Y2959
    X1009Y2959
    X1109Y2959
    X1209Y2959
    X1309Y2959
    X1409Y2959
    X1509Y2959
    X1609Y2959
    X1709Y2959
    X1809Y2959
    X1909Y2959
    T03
    X3501Y2971
    T04
    X3330Y2822
    T05
    X329Y239
    X429Y239
    X579Y238
    X679Y238
    X829Y239
    X929Y239
    X1079Y239
    X1179Y239
    X1329Y239
    X1429Y239
    X1579Y239
    X1679Y239
    X1829Y239
    X1929Y239
    X2079Y239
    X2179Y239
    X2329Y239
    X2429Y239
    X2579Y239
    X2679Y239
    X2829Y239
    X2929Y239
    X3079Y239
    X3179Y239
    X3329Y239
    X3429Y239
    X3579Y239
    X3679Y239
    T06
    X2479Y2829
    X2479Y2929
    X2479Y3029
    T07
    X3069Y2929
    T08
    X2329Y2509
    X2229Y2639
    X1999Y2639
    X1869Y2699
    X1809Y2619
    X1989Y2509
    X2099Y2269
    X1179Y3129
    X1129Y3199
    X749Y3199
    X1559Y3209
    X1989Y3209
    X2239Y3209
    X219Y2529
    X429Y1259
    X719Y1259
    X929Y909
    X929Y809
    X1189Y1249
    X1689Y1249
    X2179Y1259
    X2699Y1259
    X2689Y909
    X2689Y809
    X3149Y1259
    X3449Y1249
    X3449Y709
    M30
    Chris I.
    I got my .drd files to show up properly in View Mate. I had to change the Eagle config file and change the X,Y, Res setting from 10000 to 1000.
    Then In View Mate, I had to change the import options to the proper format:
    2 dec. left, 3 dec. right
    Omit leading zeros selected
    positon absolute selected
    units english
    character ASCii
    It all shows·lined up but thats not to say that the output is compatable with the fab houses. I would have to try to submit the files and see if it is workable.
    Thanks StarMan for your help. You certainly pointed me in the right direction.
    See screen shot to see how the drill holes indeed line up with the pads, indicating it must be correct I assume.
    Post Edited (RoboROOKIE) : 9/28/2005 5:52:18 PM GMT
    1024 x 768 - 59K
