Cylon LEDs
Hi again...
Does anyone have an idea or schematic for stringing together several red leds that would blink in sequence, similar to the cylons on the old battle star galactica.· The plan is to mount the led array on the front of the robot and have it synced with the ping sensor moving from side to side.·
(that is, of course, if I can get the ping to work.... see other posting.)
Ryan
Ryan Clarke
Parallax Tech Support
RClarke@Parallax.com
Do you mean mechanically move one??? I suppose I could dedicate a servo to do that, but electronically would be better...
Bob
Ryan
Ryan Clarke
can you give me an example to follow????
What is your design? What are you using to power your device? What control are you using?
Ryan
Ryan Clarke
Lot's of questions... let's see if I can get us started.· This is only for esthetics.· The plan was to string several red leds along the front of the robot to look like the cylon scan.· I was thinking it can all be electronic and run (and powered) by itself.· The "nice to have" piece would be to have it synced with the servo running the Ping sensor from side to side.·
I don't know enough electronics yet to put this circuit together and that's why I asked for the help.
Bob
PS> reading several of the posts on all the various topics in these forums, I am surprised someone didn't ask or come up with this before....
Bill
I tried to score the thing a couple of times to no avail, but the place changed hands a couple of months ago.
All you would need to do is pan the ping sensor at the same rate. Try
www.wackywillies .com
On second thought, I may try to get it again.
Larry
There are a lot of good LED circuits on Bill Bowden's site. I have put a few of them together and I am using one in a project now (more on that when it's done).
Hope that helps!
Doc
Post Edited (doggiedoc) : 9/28/2005 1:17:25 AM GMT
Jon Williams
Truly Understand the Fundamentals and the Path will be so much easier...
Thanks for looking in. I gathered that you can program this activity, but I didn't want to use I/O pins for this simple decoration.
I would appreciate your looking into my other post dealing with the Ping sensor not working.... This is becoming a real problem and I would really like your input.
Bob
The Ping is a no-brainer. If it's not working, it could simply be dead. I have used several, and every single one of them worked the first time. If you have a 'scope you can always look watch the trigger/echo pin for activity.· I've attached a graphic that I did for another customer that shows the Ping Trigger and Echo pulses.· Note that for this demo the Trigger pulse was stretched quite a bit so that it could be seen on the display.· This is not a problem for the Ping because it actually waits for the falling edge of the trigger pulses.
Jon Williams
Post Edited (Jon Williams (Parallax)) : 9/28/2005 5:13:30 PM GMT
Thanks for that led note... When I get to that point I will try it.
The Ping is a different story. I don't have a scope and I really don't know how to determine if the Ping is receiving or for that matter, sending back the echo times. Do you have any suggestions for testing this???
quick question... When you use the Ping, does the ACK green led on the board blink with each pulse or is it on continuously as in mine?
If it indeed "dead" do I return it to Parralax for replacement and how do I do that???
Bob
I think you should probably call Tech Support at 888-512-1024 and let them walk you through it and set-up a return if you're in warranty. The other thing you could do is post your code. All of these things are code driven and you may very well be making a mistake. I know code mistakes are a rarity <wink>, but in the off chance that's the cause none of us can help you without actually seeing your code.
Jon Williams
Formally RoboROOKIE.
Take a look at this:
http://www.bit-tech.net/modding/2002/06/22/knight_rider/1.html
I didn't look close enough to see how hard synching to the ping sensor movement would be though.
I will give them a call as the module is only a week old. To answer you question though, the code I am using is the direct download from the web site. The only modification I made, other than trying to trouble shoot, was changing the pin designation from 15 (in the program) to 0, 1, 3 etc.
Thanks again for your help with this one....
Jon Williams
Jon Williams
Post Edited (Jon Williams (Parallax)) : 9/29/2005 12:15:41 AM GMT
Jon Williams
Thanks for getting in touch with Roger on my behalf. After your last comments, I too was looking at the ARobot schematic and realized the +5V connection at each of the stamp pins. In fact I was thinking about pulling the resistor SIP and insulating the specific pin just to try it out. I decided to wait until I heard from you or Roger. Hearing this, I might want to do that anyway, since clipping the pin would dedicate that I/O pin to Ping.
When I get home tonight I will give it a try and let everyone know.
I want to add that I am very grateful for your help in this.
It works....
I pulled the SIP and clipped the pin as suggested above (I have worked with some of these types of components previously). Plugged it back in. Turned it on and loaded the program.
I blinks and returns to the debug screen all the proper data. I even tried some calibration measurements to see how accurate it was. Got my wife to hold the tape measure and it is definitely accurate to the inch. Very impressive.
I have to make sure that my plans now indicate that PIN 15 does not have the pull up voltage. Will this modification harm anything else/??
My thanks to everyone who helped out. It's too bad these threads got trapped in the LED topic and not in the sonar one. I am sure many folks would like to hear the outcome.
- Matt
