D/A converter chips??
Instead of using the PWM method to build a D/A converter, I want to use a real D/A chip.
My project is
a sinusiodal wave input from funtion generater·pass through A/D chip(ADC0831) to BS2 then D/A(DAC???)
Did anyone use a real D/A·chip to build this kind of circuit?
Please give me more information.
Thank you in advance.
My project is
Andy
I got a sample of that MAX522 DAC from www.digikey.com (Digi-Key part number MAX522CPA-ND). After fixing a mistake in the program, the part works fine. A corrected and updated program is below. Make sure to put output capacitors across each DAC output and ground as shown in the schematic on page 1 of the datasheet. They aren't kidding about the 0.1 uF cap across DAC A and the 0.01 uF cap across DAC B. Also, make sure to connect Vref to Vdd for a 5 V scale. If you are using LEDs to view the signal, use diffused light LEDs, and go with large series resistors to avoid clipping, 1 k on DAC A and 10 k on DAC B.
' ----[noparse][[/noparse] Title/Description ]------------------------------ ' Max522DualTraingle.bs2 ' Generate two triangle waves 180-degrees out of phase ' at about 1.65 Hz. Set your oscilloscope for 100 ' or 200 ms/div. ' ----[noparse][[/noparse] Directives ]------------------------------------- ' {$STAMP BS2} ' {$PBASIC 2.5} ' ----[noparse][[/noparse] Circuit/Pin Definitions ]------------------------ ' Use the schematic and pinmap on page 1 of the MAX522 ' datasheet for connecting power and filtering ' capacitors. For testing, connect Vref (MAX522 pin 7) ' to Vdd for a full 5 V scale. Basic Stamp 2, I/O pin ' connections are listed below: Din PIN 6 ' Connect to MAX522 pin 8 Cs PIN 5 ' Connect to MAX522 pin 1 Sclk PIN 4 ' Connect to MAX522 pin 2 ' ----[noparse][[/noparse] Constants ]-------------------------------------- SetDacB CON %00100010 ' See datasheet, SetDacA CON %00100001 ' page 9. ' ----[noparse][[/noparse] Variables ]-------------------------------------- dacValue VAR Byte ' D/A converter value startValue VAR Byte ' FOR...NEXT start value endValue VAR Byte ' FOR...NEXT end value ' ----[noparse][[/noparse] Initialization ]--------------------------------- LOW SCLK ' Clock low HIGH CS ' Chip select high startValue = 0 ' Initialize loop limits. endValue = 255 ' ----[noparse][[/noparse] Main Routine ]----------------------------------- DO FOR dacValue = startValue TO endValue STEP 5 LOW Cs SHIFTOUT Din, Sclk, MSBFIRST, [noparse][[/noparse]SetDacA, 255-dacValue] HIGH Cs LOW Cs SHIFTOUT Din, Sclk, MSBFIRST, [noparse][[/noparse]SetDacB, dacValue] HIGH cs NEXT ' When start value is 255, end value is ' 0, and visa versa. startValue = 255 - startValue endValue = 255 - endValue LOOPAndy
I will buy this chip and build it.
Sorry I am the new user.
There are two place that you mention I don't get·it.
1. Vref (in Max522 chip) connect to Vdd(in Stamp)
··· How about the pin Vdd (in Max522 chip)? where should it go?
2. there are two outputs, outputA and outputB
··· How can I connect to oscilloscope?
By the way, have you ever try DAC0800 series chip or DAC0830 chip as D/A converter?
Post Edited (jo) : 9/13/2005 6:19:14 AM GMT
BOE··· MAX522
Vdd····VDD & REF
Vss··· GND
P6·····DIN
P5·····CS
P4···· SCLK
2.· Here's one way to connect the oscilloscope to view both channels.· I'm guessing you'll only need one of the two channels for your project, probably OUTA.
Scope········ MAX522
Ground clip···GND
ChA·········· OUTA
ChB·········· OUTB
I've looked at the DAC0830 many times, but never bought one because it takes 12 I/O pins to operate.· I might use it with an SX52 microcontroller is speed is a major concern.· With BASIC Stamps, I try to stick with synchronous serial devices, because they usually only take two or three I/O pins.· In many cases, they can be bussed together with common·SCLK and·DIN/DOUT lines.· The only lines that need dedicated I/O pins are the CS lines.·
Thank you for your DC offset advice.
Finally,I receive MAX522 from Maxim.
I build it as Max522 datasheet and try to combine my ADC0831 circuit and program.
But I don't get any anglog output in OUTB and OUTA.
Here is how I connect this two together.
I connect the Pin 6 (ADC0831) to pin 8 (Max522)
Am I right?
Or I need to connect P0(BOE) to P6(BOE).
About program, I combine the program in Experiment 27 and the one you gave me.
Wire up your MAX522 separately from your ADC0831, and use the test program I posted on 9/12/2005 to test it.
Once you are sure it's working, then make sure the ADC0831 is working.
After that, try writing a program that first reads the ADC0831, and then sends that value to the MAX522.
