SMT Component Questions
it seems there are many footprints for smt components and it makes getting into smt designs more intimidating. i could use some guidance selecting the components for my potential designs.
1) for a reference, what are the sizes of the led's on the professional development board? i think they are 0603 but i'd like to be certain.
2) when developing smt designs should i try to keep the components the same size (footprint) for simpler pcb design & construction?
3) what size smd's are suitable for the various soldering techiniques? do you have to reflow?
future thanks for you generous advice!
nickB
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
nickB
Sid Weaver
Do you have a Stamp Tester yet?
http://hometown.aol.com/newzed/index.html
I have settled on 0805 for resistors and caps (anything I can get in that size). They are fairly small but can still be hand soldered if needed.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
Product web site: www.sxvm.com
Available soon!! Video overlay(OSD) module...
"I'm a man, but I can change, if I have to, I guess"
Red Green
I work at a company that hand solders smt components that are not machine able and I have hand soldered literally·thousands of 0603's, 0805's & 1206 components using SN96, SN63, and even some HMP solder alloys.
I can even hand solder fine pitch leads found on QFP components. Solder is very easy to work with if you have the right tip.
Greetings from Germany,
G
·1+1=10
Has a great selection of the 1206 packaged components, which seem to be the biggest SMD devices available.
I ordered a bunch of them on the "bigger is better (easier)" premise.
I wonder if this wire is hot...
·1+1=10
I have no experience with these components so I figured that the bigger ones would be better to start with.
What was it that made them harder to solder?
·1+1=10
*Get the finest tips you can.
*Tiny diameter wire solder works, but with things smaller than 0603s it becomes very difficult to control the fillets on the components.
*Solderpaste is better, especially if you have a hot air gun to work with. It's the only way to do large micropitch ICs like DRAMs and FPGAs, not that most folks here will be hand-building boards containing things like that, but even an SX52 is tough on old eyes, which can benefit from a modified reflow technique.
*Use a fume extractor. Those little parts and their little balls of solder still fry flux, and the more of that stuff you get in your face, the harder it is to see, especially if you're squinting.
*Plan on making mistakes. Practice is the only way to get good.
*Use a magnifier. I'm 26, I'm corrected to 30/20 at less than 10', and I go blind after a few hours of rework without magnification. Yes, my prescription is for close work, and yes, I can still read the labels on 0603s without squinting.
*Practice. Start big and work down. 1206s should be easy for anyone with tweezers that can hand-solder DIPs. 0805s fall into that category for most folks.0603s require some practice and a deft touch. Keep away from snaything smaller (0402s, SC70-5s, etc) unless you absolutely need to use it. It's not worth the hassle.
Hmm..that sounded more like a rant, but it's based on close to a decade of SMT rework time. As always, it's only worth what you paid for it
-dave
This is not a sig. This is a duck. Quack.
