Need a LONG serial cable for the SXKey
cbmeeks
My work bench is now behind my computer desk (instead of being crammed onto one desk).
This is working out well but I now want to run a long serial cable to the workbench. It will have to run up the wall, over the ceiling, and down the wall to the bench. So, I guestimate 25-35 feet.
Is this even possible? Can you still program the key with a long cable like that? If so, where would I get one? I assume the cable is straight-through?
http://metroidclassic.com
DMCA Sucks
RIAA Sucks
DMCA Sucks
RIAA Sucks
There are also WIRELESS serial cable extenders (saves you climbing through the attic)
There are some fancy devices that run over CAT5 up to 3300 ft. http://www.minicom.com/kvm_232.htm
The only limitation is your pocketbook.
I did google search on RS-232 Extender.
John J. Couture
San Diego Miramar College
But am I correct? Straight through?
Cause I could probably make one using CAT5
DMCA Sucks
RIAA Sucks
His book states that RS-232 length can work up to 50-100 feet (pg 6 & pg 118). Yes, straight through because you use a straight through cable when you connect using a short cable. In other words you do not use a null modem.
As far as using Cat 5 which is actually four twisted pairs. Hmmm. I don't see why not. I don't think an RS-232 cable is shielded. I would just avoid things like flourescent fixtures which have transformers and ionized tubes.
Also there are RS-232 to RS-485 converters which can communicate in the 4000 foot range.
I'm not aware of any schematic on the SX-Key but if one is not public, Gunther Daubach or Jon Williams can probably tell you how many wires in the DB-9 connector will be needed. I think the buzzword is experiment here.
Heck, you probably have an extra RS-232 cable laying around. Cut it in half, put the cat 5 in the middle and connect it up. It's either going to work or not. Could be done in less time that it took both of us to write about it. (grin).
John J. Couture
Get, or wire up a 50 ft cat5 cable, and get a pair of db9 to rj45 adapters.
The idea of rs232 to rs485 is better, and will resist noise/interfearence better.
Bob N9LVU
DMCA Sucks
RIAA Sucks
yes, it is straight through. See the attached picture for an example how you could extend the serial cable length. Using flat cable removes quite a bit of mechanical stress from the SX-Key, so I also have prepared a "short extender", better called a "stress reliever".
Greetings from Germany,
G
Just for clarity, Jan Axelson is a woman, not a man.
Thanks, PeterM
John J. Couture
Yes, they are.
Thanks, PeterM
You mentioned your cable above provides mechanical strain relief for the SX-Key. Have you found any distance limitations FROM the SX-KEY TO the SX? In other words, what if one were to make a little 4 conductor cable that plugged into the key and into the MCU assembly.
John J. Couture
Some people have successfully extended leads from the sxKey to the chip being programmed and debugged. However, it is not recommended as the clock that drives the SX chip is on those leads. If you're working on a project with a 50 or 75 MHz clock, that means you'll be sending that high speed signal across your extensions. If it works - great. If not, don't be surprised.
Extending the serial cable and using a ribbon cable for strain relief is a safe approach.
Thanks, PeterM
I agree with Peter - extending the four-pin ISP side can be critical when you use the SX-Key as clock generator while debugging, or using the IDE's "Run-Run", or "Run-Clock" options. When you use the SX-Key for programming only, extending the ISP side is less critical because the communication between the SX-Key and the SX is performed at a much lower speed.
I never tried to extend the ISP side of the SK-Key, therefore, my opinion is theoretical only. Mybe, you just give it a try, and share your experience with the group.
G
{I suppose that I just think I have to tinker with connections and work with the robot.}
But for those who do or must, a couple of rs-232 to rs-485 adapters would nicely remove the distance limitations.
I am not sure, but maybe USB is an improvement too.
G. Herzog in Taiwan
Post Edited (Kramer) : 9/23/2005 9:12:48 AM GMT
No, USB has a rip roaring distance limitation of 16 whole feet. RS-232 can go much farther (~50 feet or so) and RS-422 or RS-485 will take you into the thousands of feet range.
Thanks, PeterM
So, there's your distance problem.
Thanks for all of your suggestions guys.
Now here's another. Which of the 9 pins are actually used in the SXKey? Cat 5 only has 8 but surely not all 9 are needed for the SXKey.
thanks
cbmeeks
DMCA Sucks
RIAA Sucks
John J. Couture
The baud rate for communication between the PC and the SX-Key is 57.6 kBaud.
G
