Can I do this with the button command to test the state of six buttons? — Parallax Forums
TMartTMart Posts: 2
edited 2005-09-09 23:07 in BASIC Stamp
· DO
··· BUTTON 0,1,255,255,Workspace,1,Pressed
··· BUTTON 1,1,255,255,Workspace,1,Pressed
··· BUTTON 2,1,255,255,Workspace,1,Pressed
··· BUTTON 3,1,255,255,Workspace,1,Pressed
··· BUTTON 4,1,255,255,Workspace,1,Pressed
··· BUTTON 5,1,255,255,Workspace,1,Pressed
· LOOP
I want to test six buttons on a game, and they will stay "on" "1" after pressed while the program looks for others also pressed as the game moves on.
thanks
Ted - BeverageNJ@aol.com
    edited 2005-09-06 15:04
    Ted,
    ·· An initial problem you're going to have with this is that you're trying to use the same workspace variable for all buttons.· This will adversely affect the button command.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
    Post Edited (Chris Savage (Parallax)) : 9/6/2005 3:25:55 PM GMT
    edited 2005-09-06 15:26
    BUTTON really isn't very useful for that application -- it's cleaner to write custom code.· This will help:
    http://www.parallax.com/dl/docs/books/sw/exp/sw15.pdf
    Jon Williams
    edited 2005-09-06 16:21
    Here's another URL for an example "game show" using successive detection of button responses...
    www.emesys.com/BS2fsm.htm#Game%20show
    Tracy Allen
    www.emesystems.com
  • TMartTMart Posts: 2
    edited 2005-09-09 17:46
    First of all, thank you
    I changed the workspace element into workspace0, worspace1, etc. . . .
    Is that a good way to go about it.
    I also appreciate the other responses and am studying them to understand what they are doing, so I can grasp the concepts outlines.
    God bless
    Ted
    edited 2005-09-09 18:27
    Basicall, Ted, BUTTON is not the best choice in this application -- better to use my code or Tracy's to scan and debounce multiple inputs.
    Jon Williams
    Ted,
    ·· While I was pointing out there error in your BUTTON setup, Jon and Tracy are correct.· You're better off with their suggestions.· Better to take their advice.· =)
    Chris Savage
