Using a Nintendo 64 controller with the BOE-Bot — Parallax Forums
pcrobotpcrobot Posts: 103
edited 2005-09-08 22:07 in Robotics
Hello all,
I recently picked up a Nintendo 64 controller in hopes of using it to control my BOE-Bot. cool.gif
Attached is a pic of the controller, so you know what I'm talking about.
I thought the first place to research this idea would be here. Has anyone used a Nintendo 64 controller with the BOE-Bot, or the BOE? If so; pics, code, & schematics would be greatly appreciated! burger.gif
Thanks!
Robotics
ro-bot-ics (noun)
the science or technology of robots, their design, manufacture, application, use, etc.
    edited 2005-09-01 15:01
    http://www.mixdown.ca/n64dev/
    I haven't used this phrase in a while ... Google is your friend.
    Jon Williams
  • DiablodeMorteDiablodeMorte Posts: 238
    edited 2005-09-01 16:35
    Umm, I can help you. What do you want it to do? And I can only help you if your willing to sacrifice your controler. (sorry, I don't keep the original wiring)
  • pcrobotpcrobot Posts: 103
    edited 2005-09-02 13:37
    DiablodeMorte said...
    If you mean cutting open the cord or the case, then sure! smile.gif What do I have to do? I just want to control my BOE-Bot with it. idea.gif
    Robotics
    ro-bot-ics (noun)
    edited 2005-09-02 14:01
    If you look at the protocol you're going to find that while simple, it probably is not simple to implement on the BS2. I'm already working on an SX (using our SX/B compiler) for the Playstation controller, I may do another version that works with the Nintendo controller if there's enough interest in it. The SX could serve as an interface (you would *talk* to it with SEROUT/SERIN) between the BS2 and the controller.
    Jon Williams
    Jon Williams (Parallax) said...
    Robotics
    ro-bot-ics (noun)
