surface mount stuff in a hobby environment
I'm·in a situation where I'll be working with a surface mount component in a prototype hobby environment.· I've never played with such small pieces before, but I'm going to try to learn.
It's an 8-pin SOIC device --- so thank god that there are only 8 pins.
I've found adapters online that adapt from SOIC to DIP.· Has anyone used them?· Which ones do you use and how well do they work?·What specs do I have to match up between my device and an adapter to make them compatible?· Are decent ones affordable?
I'm trying to interface to a solderless breadboard.
I did read some of the posts from Bean's thread·regarding his latest project.
I don't currently own a "good" soldering iron, or any tips that would come close to the size I would need.· I'll take recommendations here too if the solution requires it! [noparse]:)[/noparse]
Keith
Keith
My projects are moving to SMD. I make my own boards using Pulsar Toner Transfer and etching solution and a sponge. A 15 watt soldering iron is plenty big.. I use a $24 Antex in 12 watts with a small tip--$5 more. For SMD, a small diameter solder, a flux pen meet my needs. I use a headband magnifier for solder work.
I started by buying a 100 bypass 1208 caps in .1uf and a mix of resistors in the same size. I use through hole components that I already have and mix in the SMD where they work. For example, all my DIP bypass caps are SMD between the DIP pins.
The shift can take place slowly. I am moving to SMD because some parts are no longer packaged in through hole packages. I really like not having to drill holes.
Look here:
http://www.sparkfun.com/shop/index.php?shop=1&cart=372938&cat=66&
I wonder if this wire is hot...
·1+1=10
Keith, I've mentioned it before, but I swear by the two Weller WESD51s I have on my desk here at work. Not to slight the Xytronic units, as they are quite decent, but I've found the availability of Weller tips, parts, and accessories to be superior over the years. The convenience factor is just too high for me to switch.
Hints:
-In theory, you don't need more than a few watts to solder SMT parts quickly and accurately. In practice, I've found that a slimline 20W+ iron makes it easier.
-I like a tip temperature around 650F. That's derrived from experience and literally millions of fresh and reworked solder joints.
-I use the tiniest tips available.0.8mm seems to stick in my head.
-63/37 (eutectic) rosin core solder from a good manufcaturer (Kester or Multicore IMHO) is a requirement.
-A Kester or similar flux pen wiped across the PCB pads before you put down the part helps out a lot.
-DO NOT handle the leads or the PCB pads you plan to solder. Use tweezers or a vacuum pen. The oils in your skin will make it harder to solder parts. I know there's folks who will counter me on this, but 3 years as a solder joint metallurgist and QA inspector in a fortune 100 manuf research lab taught me more than I ever wanted to know about good and bad solder joints.
My $0.02
-dave
This is not a sig. This is a duck. Quack.
How do you keep the component on the header PCB when you solder it? I'm assuming the first pin soldered should hold it in place, but what about before that? I'm guessing this is especially crucial because the darn leads are so small, a slight offset can screw up everything.
Keith
One trick is to take a piece of wire, one end stuck into plywood. The other end bends in an inverted "U". The circuit board is placed under the open end and the wire tip presses the component into position.
Knight.
For larger package SMT ICs I put solder on the tip of the iron, hold IC down with one finger and solder as many leads as I can before I run out of solder. If I can't hold my finger on the chip, then it's getting too hot so I quit soldering immediately to let it cool down.
Of course I use a flux pen on all the pads first.
I have gotten pretty good at soldering the SX48 (0.5mm pitch). Someday I want to make a video of it to show ya'll.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
Product web site: www.sxvm.com
"One experiment is worth a thousand theories"
.015, .020, .031 ??
Paul mentioned Howard Electronics. Is there any other one-stop shopping place that deals in SMT equipment, pieces, parts for the hobbyist ??
Keith
I soldered an SX20 onto a sparkfun board by clamping it in place with a needlenose vise-grip.
Then I heated one whole side of pins at the same time with a 45W soldering wedge and dragged a swath of 60/40 solder accross it. The next step was to press solder wick against the pins with the iron to clean up all the bridging.
It seems to have worked though...
Keith, another good place to look for bulk components is here:
http://www.futurlec.com/
They have very good prices on basic components and don't brutalize you with shipping rates.
You might also want to look at
www.mouser.com/
They have an amazing variety, but are a little pricier than futurlec.
Here is one of my favorites from them:
]www.mouser.com/index.cfm?&handler=data.listcategory&D=*l78s05cv*&terms=l78s05cv&Ntt=*l78s05cv*&Dk=1&Ns=SField&N=0&crc=true]
The L78S05CV voltage regulator puts out 5V of smooth current at up to 2 amps for only 46 cents each.
These are perfect for powering up an SX project.
Post Edited (Electronegativity) : 9/2/2005 3:18:35 AM GMT
what if a flux pen, and where are they?
a remember watching a "how to drag solder" video that someone posted some time ago and they mentioned reflow flux.
i've been looking but cannot find any. any help?
also if you use a hot plate to reflow solder on smt components what tools do you need? i think someone mentioned a syringe once to apply solder to pads.
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
Sid Weaver
Do you have a Stamp Tester yet?
http://hometown.aol.com/newzed/index.html
Sid Weaver
If there's already solder on the pads then why can't I just use that to attach it to the board?
Sid
What is the best solder to use for SMD?
I have been using 60/40 because I can't seem to get the lead free stuff to melt right.
Its like I have to apply way too much heat.
Sid
I dispense the paste with a syringe. But the componets on it. Then reflow it with the wand.
The wand I use is a SUNKO 850A I bought from sparkfun.
Bean.
Available soon!! Video overlay(OSD) module...
"I'm a man, but I can change, if I have to, I guess"
Red Green
Begin with a small soldering iron, 15 watts or less and a small tip. Get a tube of liquid flux and some .015 or .020 solder. A small size Soderwick completes the materials. A headband magnifier and tweezers complete the package.
All this stuff can be purchased for about $40. I have good luck with this simple system. You can always spend more if you find this process falls short in any way.
Sid Weaver
http://www.coldheat.com/
The Home Depot carries the original unit. I know this isn't a professional grade soldering unit, but the concept is intriguing. If not for SMD, how does this work for "conventional" electronics soldering?
John R.
·1+1=10
Thanks for the money saving advice.
John R.
