seven segment time recorder
hello,
I am attempting to create counter using seversl seven segment leds. I would like for the display to go up in value for x-amount of time based on an ir input. for instance, if a person is in front of the sensor the counter goes up; when nobody is front of the sensor the counter goes down.
I am considering using a TLC555 timer. I have no experience with this IC.
can anyone please pass advice as to where I can start?
thank you
thank you
Jon Williams
Chris Savage
Parallax Tech Support
csavage@parallax.com
is the MC14489 completely needed? I would like to get started right away, and not wait for the part. thanks.
chris,
i do plan to attempt the SX, the starter kit is back ordered though.
Jon Williams
