Accessing memory locations (2px)
I have finished the book "What's a micro controller" using the Basic Stamp2. I want to get the Basic Stamp 2px next, but I was wondering how do you access each of the eight 2k memory slots when programming? Can someone give me a simple code example demonstrating the usage of say just two slots, going from one slot to the other?
·· The command needed·is the RUN command.· STORE can also be used to affect which banks are used by READ/WRITE commands.· A simple bank switching program would be:
' {$STAMP BS2px, PROG2.bpx} ' {$PBASIC 2.5} DEBUG HOME, "HELLO, THIS IS THE FIRST PROGRAM SLOT!", CR PAUSE 1000 RUN 1
Below is PROG2.bpx
' {$STAMP BS2px} ' {$PBASIC 2.5} DEBUG "HELLO, THIS IS THE SECOND PROGRAM SLOT!", CR PAUSE 1000 RUN 0
This will alternate between slot 0 and slot 1.· Of course, a·good idea would be to read the Nuts & Volts article at the following link.
http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv87.pdf
Chris Savage
Parallax Tech Support
csavage@parallax.com
Jon Williams
