play station controller for bs2e
·hello,
········ is there anyone out there that can give me an
idea or help programming my bs2e to work with the ps2 controller.
········· i want to assign each button & joystick to different movement for my bipedal robot. but i don't know how to do it. i have seen it done at lynxmoition but it's done for bs1 not 2e. tried to convert it to work with it but i keep getting
errors.
any help would be great!!!!
thank you,
robonetics
aka charlie
idea or help programming my bs2e to work with the ps2 controller.········· i want to assign each button & joystick to different movement for my bipedal robot. but i don't know how to do it. i have seen it done at lynxmoition but it's done for bs1 not 2e. tried to convert it to work with it but i keep getting
errors.
·any help would be great!!!!
thank you,
robonetics
aka charlie
thankz again robonetics
' {$STAMP BS2e}
' {$PBASIC 2.5}
' This program allows the remote control of a differentially steered robot
' from the Sony Play Station 2 game controller.
' The Scorpion has two modes of operation. The default is the mixer mode. This
' is where you have a Throttle for forward and reverse speed control, and a
' Steering control for turning. In this mode the left input is throttle and
' the right input is steering. The other mode is a differential style control.
' This is where the left and right channels are controled indepentantly to
' steer like a tank. This program uses the mixing mode. It also requires the
' BEC (battery eliminator circuit to be dissabled. See the Scorpion manual.
'Connections
'Pin 0 Left Scorpion channel.
'Pin 1 Right Scorpion channel.
'Pin 2 Pan servo.
'Pin 3 Tilt servo.
'Pin 4 PS2 Data
'Pin 5 PS2 Command
'Pin 6 PS2 Select
'Pin 7 PS2 Clock
'Pin 8 NA
'Pin 9 Speaker
'Pin 10 1/0 Controlled from Triangel Button
'Pin 11 1/0 Controlled from "X" button
'Pin 12 Gripper up/down servo.
'Pin 13 Gripper rotate servo.
'Pin 14 Gripper open/close servo.
'Pin 15 NA
DAT CON 4 ' Play Station game controller connections.
CMD CON 5
SEL CON 6
CLK CON 7
temp VAR Byte ' Variable definetions.
button1 VAR Byte
button2 VAR Byte
bpress1 VAR Bit
bpress2 VAR Bit
rhori VAR Word
rvert VAR Word
lhori VAR Word
lvert VAR Word
ldrive VAR Word
rdrive VAR Word
servo0 VAR Word
servo1 VAR Word
servo2 VAR Word
servo3 VAR Word
servo4 VAR Word
servo5 VAR Bit
servo0 = 1500 ' Start the servos at mid position.
servo1 = 1500
servo2 = 1500
servo3 = 1500
servo4 = 1500
LOW 0 ' Ensure pulsout commands are positive going.
LOW 1
LOW 2
LOW 3
LOW 12
LOW 13
LOW 14
LOW 10 ' Ensure device connected to pin 10 and 11 is off on startup
LOW 11
HIGH CLK ' Ensure CLK is negative going.
PAUSE 1000
setup:' This section sets the PSX Controller to Analog Mode. (red LED should light)
' This will work with Sony and Madcatz wired, but not with Medcatz wireless.
' You must press the analog button on the controller to set to analog mode.
LOW SEL
SHIFTOUT CMD,CLK,LSBPRE,[noparse][[/noparse]$01\8,$43\8,$00\8,$01\8,$00\8] 'Config Mode Enable
HIGH SEL
PAUSE 100
LOW SEL
SHIFTOUT CMD,CLK,LSBPRE,[noparse][[/noparse]$01\8,$44\8,$00\8,$01\8,$03\8,$00\8,$00\8,$00\8,$00\8] 'Set Mode TO Analog AND Lock
HIGH SEL
PAUSE 100
LOW SEL
SHIFTOUT CMD,CLK,LSBPRE,[noparse][[/noparse]$01\8,$43\8,$00\8,$00\8,$00\8,$00\8,$00\8,$00\8,$00\8] 'Config Exit
HIGH SEL
main:
GOSUB get_PSX_data
lvert=255-lvert ' Changes vertical up from 0 to 255 and vertical down from 255 to 0.
lhori=255-lhori
ldrive=((lvert*3)+1116) ' Converts a 0-128-255 value to a 1116-1500-1881 value.
rdrive=((lhori*3)+1116)
ldrive=((lvert*4)+1000) ' Converts a 0-128-255 value to a 1000-1512-2020 value.
rdrive=((lhori*4)+1000)
'SEROUT S_Out,i57600,[noparse][[/noparse]DEC3 lvert\3," ",DEC3 lhori\3," "]
'SEROUT S_Out,i57600,[noparse][[/noparse]DEC5 ldrive\5," ",DEC5 rdrive\5," ",13]
servo0=((rhori*4)+1000)
servo1=((rvert*4)+1000)
IF rhori > 208 THEN ' Pan servo routine.
servo0 = servo0 + 25
ELSEIF rhori > 148 THEN
servo0 = servo0 + 5
ENDIF
IF servo0 < 750 THEN
servo0 = 750
ENDIF
IF rhori < 48 THEN
servo0 = servo0 - 25
ELSEIF rhori < 108 THEN
servo0 = servo0 - 5
ENDIF
IF servo0 > 2250 THEN
servo0 = 2250
ENDIF
IF rvert > 208 THEN ' Tilt servo routine.
servo1 = servo1 + 25
ELSEIF rvert > 148 THEN
servo1 = servo1 + 5
ENDIF
IF servo1 < 750 THEN
servo1 = 750
ENDIF
IF rvert < 48 THEN
servo1 = servo1 - 25
ELSEIF rvert < 108 THEN
servo1 = servo1 - 5
ENDIF
IF servo1 > 2250 THEN
servo1 = 2250
ENDIF
' Gripper open/close
temp=button2 & 2 ' Filter out all but bit 2, R2.
IF temp=0 THEN ' If button is pressed then do the following.
servo4 = servo4 - 25 ' Open the gripper.
IF servo4 < 750 THEN ' Hold the value to 750 minimum.
servo4 = 750
ENDIF
ENDIF
temp=button2 & 8 ' Filter out all but bit 8, R1.
servo4 = servo4 + 25 ' Close the gripper.
IF servo4 > 2250 THEN ' Hold the value to 2250 maximum.
servo4 = 2250
ENDIF
ENDIF
' Gripper up/down
temp=button1 & 16 ' Filter out all but bit 16, D-pad up arrow.
servo2 = servo2 - 25 ' Lift gripper.
IF servo2 < 750 THEN ' Hold the value to 750 minimum.
servo2 = 750
ENDIF
ENDIF
temp=button1 & 64 ' Filter out all but bit 64, D-pad down arrow.
servo2 = servo2 + 25 ' Lower gripper.
IF servo2 > 2250 THEN ' Hold the value to 2250 maximum.
servo2 = 2250
ENDIF
ENDIF
' Gripper Rotate
temp=button1 & 32 ' Filter out all but bit 32, D-pad right arrow.
servo3 = servo3 - 25 ' Gripper rotate right.
IF servo3 < 750 THEN ' Hold the value to 750 minimum.
servo3 = 750
ENDIF
ENDIF
temp=button1 & 128 ' Filter out all but bit 128, D-pad left arrow.
servo3 = servo3 + 25 ' Gripper rotate left.
IF servo3 > 2250 THEN ' Hold the value to 2250 maximum.
servo3 = 2250
ENDIF
ENDIF
' I/O on/off
temp=button2 & 16 ' Filter out all but bit 16, Triangle button.
IF temp=0 AND bpress1=0 THEN ' This makes a latching output pin that responds to button presses.
bpress1=1
TOGGLE 10
ENDIF
IF temp<>0 AND bpress1=1 THEN
bpress1=0
ENDIF
temp=button2 & 64 ' Filter out all but bit 64, X button.
IF temp=0 AND bpress2=0 THEN ' This makes a latching output pin that responds to button presses.
bpress2=1
TOGGLE 11
ENDIF
IF temp<>0 AND bpress2=1 THEN
bpress2=0
ENDIF
' Send out the servo pulses
PULSOUT 0,ldrive ' Left Scorpion channel.
PULSOUT 1,rdrive ' Right Scorpion channel.
PULSOUT 2,servo0 ' Pan servo.
PULSOUT 3,servo1 ' Tilt servo.
PULSOUT 12,servo2 ' Gripper up/down servo.
PULSOUT 13,servo3 ' Gripper rotate servo.
PULSOUT 14,servo4 ' Gripper open/close servo.
PULSOUT 15,servo5
PAUSE 20
GOTO main
get_PSX_data: ' This section gets the data from the PSX controller.
' The first shiftin gets the mode. (73)
' The next 2 shiftins gets the pushbutton data.
' The next 4 shiftins gets the analog joystick data.
LOW SEL
SHIFTOUT CMD,CLK,LSBPRE,[noparse][[/noparse]$1\8,$42\8] ' Initiate request for data from PSX controller.
SHIFTIN DAT,CLK,LSBPOST,[noparse][[/noparse]temp\8] ' This is the Mode value, it will be dumped.
SHIFTIN DAT,CLK,LSBPOST,[noparse][[/noparse]button1\8,button2\8] ' This puts the button data into two byte variables.
SHIFTIN DAT,CLK,LSBPOST,[noparse][[/noparse]temp\8] ' This retrieves the RH byte variable.
rhori=temp ' This plugs the value into a word variable.
SHIFTIN DAT,CLK,LSBPOST,[noparse][[/noparse]temp\8] ' Note: This is necessary because the shiftin command
rvert=temp ' can't use a word variable with a byte wide shift.
lhori=temp
lvert=temp
HIGH SEL
' remove the rems (') to see the joystick values in terminal 1.
' SEROUT S_OUT,i57600,[noparse][[/noparse]BIN button1\8," ",BIN button2\8," "]
'SEROUT S_OUT,i57600,[noparse][[/noparse]DEC3 rhori\3," ",DEC3 rvert\3," ",DEC3 lhori\3," ",DEC3 lvert\3," "]
'SEROUT S_OUT,i57600,[noparse][[/noparse]13]
RETURN
