sx48 proto board power in
hi all,
is there any reason why i cant use 12 vt dc in to the sx48 proto ? its silk masked 6-9, but i'm developing a 12 vt application, and will be using 12 vt ssr's also
the schematic shows 6-30 vts
also i need a low cost way to boost the 12 vts to 24 vts , low ma to power a sensor. any ideas ?
thanks,
dan
thanks,
dan
Jon Williams
Ken
In turn, you might find yourself having to triple the voltage to deal with voltage drops in the amplifier stage.
Is this too conceptual? Do you want a small chip or a schematic?
G. Herzog in Taiwan
this is a linear magnflux transducer, senses position from interaction with a nearby magnets field, and sends out the time dependant pulse for it, ---|___________|
uses the falling edge , im researching using the sx48's 16 bit timer to give me some resolution..... the only problem so far is the examples are all in assembly, and i've been going at SX/B.... so its like a monkey looking at a piece of paper , knowing theres a banna there , but just not able to read....
dan
