uploading a program FROM the Javelin?
After a fatal disk crash i have lost all my recent Javelin code. Is there any way to backup the program that is stored in the javelin memory. I guess it´s impossible to recreate the Java code, but i would be helped to be able to store the last working version i havew in the Javelin while writing and testing my new code. I hop this made sence...
Best regards
Magnus
Best regards
Magnus
Jon Williams
Magnus
There is software that does that. For example:
http://members.fortunecity.com/neshkov/dj.html
Magnus
Jon Williams
It was worth the try to ask. I'm allready on the way rewriting everything... They say this is the best way to get better software anyway...
It just takes some some time...
/Magnus
Jon Williams
I·know that you can recreate assembly code from the machine code (1 to 1 mapping), but it is (was?) almost impossible to recreate a higher level level language from machine code.· Why is this?·
If you knew the compiler used (and its algorithms) would·it be possible?
Nate
There do exist Java bytecode decompilers. Using them can be very educational -- but you STILL lose meaningful variable names.
It may be possible to get *A* version of the higher level language code that FUNCTIONS, but not get THAT EXACT CODE (here is where the improbability engine kicks in)-
Ryan
Ryan Clarke
Parallax Tech Support
rclarke@parallax.com
