Salvage
I am cleaning out my basement today, and suddenly I see the old junky computer boards in a new way.
"Hey, that's a 26 pin header!"
"This one has half a dozen good surface-mount capacitors."
"I wonder if I can re-use that serial port connection somehow?"
One man's garbage is another man's gold.
I wonder if this wire is hot...
The pleasure I derive from taking things apart is probably not normal
i also do the same thing, once when was in 3rd grade we had to teach the class something and i taught the class how to "properly" take apart a walkman, but that was back in the "whats a screw?" era where my tool box consisted of various standard screw drivers and a hammer (and of course band-aids for when the screwdriver slips when you hit it with the hammer)
also you can steal the BNC connector off of an old NIC card and still use the NIC with no bad effects I have learned
just my 2 cents
Dave
Post Edited (Dave Lewis) : 8/26/2005 8:27:22 PM GMT
I recently did a demo on a system that will switch some motors, a large fan and some heaters. The demo used small motors that were off an HP printer, the fan was off a Pentium 3 chip and the heaters were yellow and red LEDs salvaged from an OKI printer.
I recon the demo was better than the real thing is going to be.
Kind regards from Kwa Dukuza
John Bond
Ill post a picture of the mystery sensors sometime to see if anyone has seen anything like it.
·1+1=10
