Davis Wind Speed anemometer
I am trying to build a wind speed anemometer with the davis anemometer which uses a reed sw and the count command to measure the rpm (bs2sx). I have all the info for the sensor from the OWL2 page (26rpm for each mph wind speed).
When the rotating cups stop near the point when the reed sw is closed i get very wrong data.
The OWL2 page mentions this and sugests to use the swiched supply of 5.12V(?)
Please help
Please help
·1+1=10
It is a good idea to include a debounce RC circuit, because the contacts in the reed relay will bounce, and that can fool the COUNT command into reporting a wind speed much higher than it really is. I've attached a debounce circuit.
This uses two pins. Pin p8 is used for COUNTing the reed switch, and pin p9 is made HIGH to activate the pullup resistor, with the capacitor there for debouncing. You could tie the pullup resistor to +5 volts, if the current drain through the pullup resistor is not a concern for low power operation. The anemometer cups will often stop with the reed switch in the closed position. The purpose of the 270 ohm resisotors is to limit current from the capacitor in the Stamp and in the reed switch.
The anemometer cups do not need a regulated power supply. The regulated power supply is for the wind vane, which is a potentiometer.
http://emesys.com/OL2wind.htm <-- I need to edit that page. Davis is reporting that the windspeed constant is a little different than I have there. Now it is 0.4444 Hertz per mph. 60 Hertz in a 135 mph wind. 2.25 mph per Hertz.
Tracy Allen
www.emesystems.com
I was using the shematic from the count example (basic stamp editor help) and before I read your e mail I tried to pass the signal from the anemometer through a Schmitt Trigger (74HCT14) and it seems to work much better. I am going to test your schematic tomorrow...
Now I have some trouble converting the scale to work with the BS2SX. I probably dont understand the timing of the count command. How did you calculate the 2.308 sec that will give a direct reading in mph?
Please help.
N = T * mph / 2.25
proportional to the wind speed (here in mph) with a conversion factor of 2.25. That is, iby counting for 2.25 seconds, you are left with,
N = mph
The count comes out directly in mph. I used 2.25 here instead of 2.308. That is because 2.25 is the figure that Davis is giving out now for the proper calibration factor for their anemometers, including the new Vantage Pro 6410.
On the BS2 and BS2e, the command to get the result directly in mph is thus,
COUNT 0, 2250, resultMPH ' BS2, BS2e
On the BS2sx, the command is,
COUNT 0, 5625, resultMPH ' BS2sx
That gets the same amount of time, because the 'sx uses time intervals of 0.4 milliseconds instead of 1 millisecond, and 0.4 * 5625 = 2250 milliseconds.
To get the result in other units, the equation is similar. Say, meters per second...
N = T * mps / 1.00575
COUNT 0, 1006, resultMPS ' BS2, 2e
Tracy Allen
www.emesystems.com
I did try your schematic for the anemometer today and it works fine.
I am not sure if the Schmitt Trigger is better but since it works fine with just a capacitor, I quess there is no need to use the Schmitt Trigger.
Another problem now is that when you use the COUNT command you slow down the hole basic stamp program which updades every 2.3 seconds or every 1 second if you use m/sec.
I was wondering if there is a way to make it faster, use a different method like the PULSIN command in order to make it faster. Will it work with the Pulsin?
Many thanks
Now, will this be a serious issue? I don't know, but you can test the two different methods by placing the anemometer a fixed distance and position in front of a fan and compare the two to find out.
<edit> Well it seems I stand corrected, see below post for an explaination why. Tracy is much more knowledgable in this than I am, so follow his advice. </edit>
·1+1=10
Post Edited (Paul Baker) : 8/11/2005 4:56:38 PM GMT
I know what you mean about the time it takes to COUNT the wind speed. To get a good picture of a gusty wind, you need to sample quite often and record the average and maximum. Infrequent samples tend to grossly underestimate windspeed. Note that the Davis weather stations do in fact update their readings once every 2.25 seconds. In a data logger, you could sample the wind once every 10 seconds, leaving plenty of time for other stuff or for power-conserving SLEEP.
PULSIN by itself does not work, because the wind cups signal is frequently longer than the maximum PULSIN value (0.131 second for the BS2--corresponding to windspeed >17mph). The cups are often completely stopped. And you would have to measure both the high-time pulse and the low-time pulse, because the dwell time of the reed switch is not well controlled. You might figure out a way to do it with a program loop, but it gets messy.
Now I often use an external counter chip to offload the windspeed and rain gage counting from the Stamp.
Tracy Allen
www.emesystems.com
You are upsolutely correct about the PULSIN command. It is too fast for the anemometer.
Maybe for a fast tach aplication will work ok...
The external counter that you mentioned is the frequency to voltage converter circuit you have on your internet page? Could you please explain how to use it with the bs2.
Thank you in advance.
Tracy Allen
www.emesystems.com
·1+1=10
btw Hats off to your website Dr. Allen, it has been a valuable resource of the years!
isn't all this switching unnecessary?
There seem to be a lot of ways to build this device - DC motors, magnet on a shaft and a hall effect sensor, a cam driven switch..
Wouldn't a DC motor and a generator provide a variable voltage according to wind speed? This could then be directly read by the BasicStamp through a voltage divider.
If the motor requires a high rpm, one that is geared down might be useful.
The only problem is that some DC motors have a diode inside to prevent reverse connect [noparse][[/noparse]a 12V computer fan motor for instance].
I do realize that this would have to be calibrated. Once the electronics are right, maybe a ride in the back of a pickup truck on a calm day would do the trick.
By the way, I have two 5.1 volt power supplies from old PDAs. The first was a Sony CLIE @2amps and the second was a Tungsten E @ 500mA. They are quite handy because you can insert a polarity protect diode in your project and a have near perfect 5volts from the wall wart.
G. Herzog in Taiwan
Tracy Allen
www.emesystems.com
John J. Couture
San Diego Miramar College
Can I use this as an external counter for the anemometer and if I can how i will modify it for the anemometer
Thanks for any help
·1+1=10
The counter will count each pulse from the anemometer and then I will retrieve the counts with the bs2. I need to know the number of pulses at a specified time interval. The counter will count for a specific time by itself? How i will specify the time interval?
Thanks for your help
LOW CCLR
HIGH CCLR
PAUSE delay
LOW SHFTLD
HIGH SHFTLD
SHIFTIN Q7, SCK.....
This is just an example, you'll have to fiddle with it to arrive at functioning code, such as choosing the correct SHIFTIN mode.
Hope this helps.
·1+1=10
Do you know of a timer ic with serial output so that I will not need the parallel to serial converter ic?
http://www.semiconductors.philips.com/acrobat_download/datasheets/PCF8583_5.pdf
Check point 7.8·Event counter mode on page 11·in the·datasheet, counts up to 1 million!!!
Post Edited (Orion) : 8/27/2005 3:03:38 AM GMT
Tracy Allen
www.emesystems.com
