older BS@ software
hey,
i cannot find the older versions of the PBASIC editor, i was wondering where i could get it beacuse i want to put the software on an older laptop not just my desktop and the laptop only has flopy, the 6MB v2.2 file is too large 4 floppy!
Thanx a bundle,
MM
Thanx a bundle,
MM
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 8/23/2005 10:34:25 PM GMT
Beau is a living archive of Parallax stuff. You have summoned him from the depths of his closet and he has emerged with the DOS editors. He probably has a DOS machine or two laying around.
Seriously, if you are looking for a 2.2 MB Windows Editor then use this one: http://www.parallax.com/dl/sw/bs/win/SetupStampEditorv22.exe It's the same as the 6.5 MB version except it does not require an internet connection during install. There must be a way to get this file onto two disks and then onto your laptop.
And yes I do have a couple of DOS machines
MM,
What version of "Windows" are you running on the laptop? ..and what version of the Editor would you
like to use (ignore size for a moment). I have a program, that will "fragment" a large file into manageable
"disk friendly" chunks that can be re-assembled.
Beau Schwabe
IC Layout Engineer
http://www.dekabyte.com/filesplitter/
DTQ
·1+1=10
This is a bare bones DOS program that will spit out fragmented files of the original.
When you have all of the files starting with the word "fragment" copied to your other machine, simply type fragment
( A DOS bat file created by FRAG.EXE ) and the original file will be re-constructed.
I have also included the source code...
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 8/24/2005 7:19:18 PM GMT
The easiest way to run this is to place FRAG.EXE in the same directory as the file you wish to split, or link FRAG.EXE into your path.
Type:
FRAG {your filename}
The default is for a 1.44Meg disk if you type FRAG without a filename a pseudo help screen will appear.
Here you will have a several (depending on original file size) of files generated that start with "FRAGMENT".
Most of them will have a size of 1440000 .... What you need to do here is copy each fragment file to a disk
where it can later be copied to another machine.
Eventually you will copy ALL and ONLY the files with "FRAGMENT" in the prefix to your other machine.
On the other machine type...
FRAGMENT
...in the location you copied the "FRAGMENT" files to, and the original file should be re-assembled.
Beau Schwabe
IC Layout Engineer
I have a few of those, too...
(two 3/25 machines and a 4/25.)
I'm currently 'rebuilding' one of the 3/25's, though....
(More like hack and slash as in Frankenstein)
Incidentally, you can speed these beasts up considerably by replacing the HDD with a CD-card adapter and using a fast CF-card. Saves on the battery, too...
Not to mention that it makes transferring large files much easier. Just pull the CF out and plug it into a CF-card reader on another machine.
(That means having to cut a hole in the side of the Compaq, to get easy access to the HDD bay, though)
Don't visit my new website...
