Ramdom numbers
in order to test my project i need to have my stamp generate a number randomly between 1 and 4 every 3 seconds or so. Doesnt have to be exact. i am just having issues with the random part. how would i write this code.
It's Only A Stupid Question If You Have Not Googled It First!!
Main:
· DO
··· RANDOM randVal
· LOOP UNTIL (Select = Pressed)
· selection = randVal // 4 + 1
· ' rest of your code here
· GOTO Main
'Select' is the button definition (PIN) and 'Pressed' is the button state when pressed (1 or 0).
Jon Williams
Jon Williams
I know some people that seed off of variations of the system clock (on computer code)- this still isn't *true* randomness, but since it is then dependent on when you start the program and variations from the system clock it can appear very random indeed.
Ryan
Ryan Clarke
Parallax Tech Support
rclarke@parallax.com
