Advice?
MacGeek117
Will this circuit for the SX work?
bugg
Boe-bot: $229
Toddler: $249
Learning Google is your friend: priceless
bugg
Boe-bot: $229
Toddler: $249
Even with those fixes the circuit will do nothing without code.· If you have a PDB, you can breadboard and test that circuit and code to your heart's content.
Jon Williams
Post Edited (Jon Williams (Parallax)) : 8/17/2005 1:02:56 PM GMT
If you are sincerely interested, why don't you try it, then if it does you will know, and if it does not, then you will know that too. If it does not work, and as Jon said you will need associated software, you should then ask the questions as to why it might not work.
Do some of the investigating yourself instead of just asking casual questions for others to investigate things for you.
If you're serious, GET INVOLVED!......,then I'd be happy to help.·If you're not serious, don't waste my time.
Peter (pjv)
bugg
Boe-bot: $229
Toddler: $249
