Need advise on PCB design. Hm55b compass placement.
Hi
I'm thinking about placing my stamp and some of my sensors on a PCB so I can easily move them from one robot to another. But regarding the compass, is there large problems involved in placing it in a corner of the PCB. Should the compass always be separated from the rest of the electronics?
Advise/opinions anyone?
·· Not necessarily all the electronics, but power wires and motor leads can be two source of EM fields that can affect the operation of any compass module.· This is also true to magnetic devices such as motors and servos.· So if your compass module is too close to some of these things without shielding, you can expect degraded accuracy.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Voltage regulator 6-15V to 5V @ 30-240mA
Stamp
pcf8574 ( up to 200mA)
Accelerometer ( 4mA)
ADC ( 1mA)
Compass ( 13mA)
The power leads to the servos can have a top current of 3,4A. And of course that will produce a strong magnetic field. But how strong fields does an IC produce(not the power leads to the IC). I think that the pcf8574 can consume most power of the components, but I'm not sure how large fields 200mA in a power lead produce.
0.2A and 1cm away = 0.04 Gauss ( I think)
And placing + and - wire parallel next to each other would further reduce the field (i think)
Post Edited (diafysal) : 8/2/2005 4:46:24 PM GMT
So it (compass) will be placed separate from the PCB.
(nearly done with the design)
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
