crystal oscillator tunner question
Hello smarter people...
is there such a thing as a crystal oscillator tunner?
what kind of crystal oscillator could i use to generate 1200 BAUD (besides the 4.4336 mhz crystal)
is it possible to make the bsx2 simulate a 4.4336mhz signal? the crystal oscillator needed is a bit difficult to obtain.
it would be greatly appreciated
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
trying to tie the freqout feature of the bsx2 to run the timing (oscillator) for the fsk chip
if you have a way...i could sure use the guidance
thanks in advanced
·· That's not going to work.· If the chip requires a crystal or resonator, you will need it.· The BASIC Stamp will not replace/substitute a precision clock source.
Chris Savage
Parallax Tech Support
csavage@parallax.com
but i least i know now.
so there are no "tunable" oscillators?? they are just made to a certain freq??
...or a programmable frequency synthesizer might work for you.
http://www.uoguelph.ca/~antoon/gadgets/pll/pll.html
http://members.tripod.com/~Malzev/comp/mb1505.htm
http://www.cbsite.nl/modif/onderdelen/mc145106.htm
Beau Schwabe
IC Layout Engineer
Chris Savage
TO MOVE A CRYSTAL UP YOU HAVE TO LAP GRIND THEM. TOOTHPOWER OR FINE CLEANSER POWERER IS WHAT I HAVE USED. BE READY WITH A GOOD SUPPLY OF CRYSTALS AND HOURS OF PRACTICE TO BE SUCCESSFULL. WASH CAREFULLY AFTER GRINDING BEFORE REASSEMBLING. PUT A SMALL PILE OF CLEANSER ON A PLATE OF WINDOW GLOAS ABOUT 6" SQUARE. WET NOT DAMPEN SO IT IS LIKE WATERY MUD. PUT CRYTALL IN THE MIDDLE OF THE MESS. PUT YOU INDEX FINGER CENTERED ON THE CRYSTAL AND MOVE IN FIGURE EIGHT PATTERN. DO THIS LIGHTLY ON BOTH SIDES. CLEAN REASSEMBLE AND TEST OFTEN. TO CHECK FOR ACTIVITY AND ACCURACY.
WHEN REASSEMBLING, BE SURE THE METAL PLATES HOLDING THE CRYSTAL HAVE THE CORNERS BENT TOWARD THE CRYSTAL, NOT AWAY. THE CRYSTAL OCILLATES WHILE BEING SUPPORTED ON THE VERY CORNERS. IF YOU BREAK A CORNER OFF. DISCARD AND START OVER. IF WILL NO LONGER BE USEABLE. IF IT DOES OCILLATE IF MAY HAVE SPURIOUS FREQUENCIES WHICH ARE WAY OF FROM WHAT YOU WANT.
KEY WORDS SLOWLY. CAREFULLY. VERY FRAGILE. GOOD LUCK COMES WITH MUCH PRACTICE.
73
SPENCE
K4KEP
PS. FORGOT TO MENTION. IF YOU HAVE A SUPPLY OF PICO FARAD 1-30 SAY. CAPACITORS YOU CAN PAD THE CAPACITOR LOWER ONLY IN PARALLEL. TRY PARALLELING SEVERAL IN PARALLEL WITH CRYSTAL.
IF YOU ADD CAPACITORS IN SERIES IT SHOULD RAISE FREWENCY SLIGHTLY.
S
Post Edited (SPENCE) : 8/13/2005 9:56:41 PM GMT
