How to differentiate between BS2p24 and BS2P40?
Is there a way to use the built-in $STAMP (or something else) to make a compile-time differentiation between the 24-pin and the 40-pin BS2p?·
I know I can do:
I would like to do something like:
I did not run across this·information in the Help file; the closest I can find is in the AUXIO / MAINIO / IOTERM Example; but that example does not distinguish between the 24-pin and the 40-pin BS2p.
Daniel
Post Edited (daniel) : 8/4/2005 4:02:47 AM GMT
I know I can do:
#IF $STAMP <> BS2p #THEN
#ERROR "Requires a BS2p"
END
#ENDIF
#IF $STAMP <> BS2p40 #THEN
#ERROR "Requires a 40-pin BS2p"
END
#ENDIF
Daniel
You could make your own directive:
#DEFINE BS2PTYPE=40 ' or 24
#IF BS2PTYPE=40 #THEN
AUXIO
DIRS=$FFFF
#ENDIF
That directive could also enforce the type=40 with the #ERROR message, just as a reminder of the type required.
Tracy Allen
www.emesystems.com
Thanks for the tip.· I'll make use of that somehow.
As for the original request, I'm looking for that additional bit of chip-level information that, as you suggest, already exists.· Specifically, I would expect that
#IF $STAMP = BS2p #THEN
would be true for any BS2p.
I'm looking for the chip's self-report to additionally allow me to differentiate between the different BS2p.· I don't think I require that I be able to assign the BS2p40 attribute, just that the Identify function be able to distinguish between them.· I'd be willing to use another built-in constant, such as $PINCOUNT or $MODEL·to allow the differentiation, as
#IF $STAMP = BS2p AND $PINCOUNT = 40 #THEN
Daniel
