Schematic for "Beam Break" IR sensor for Stamp?
Vern Graner
Does anyone have a quick link to a schematic and part numbers to use for creating an IR "beam break" style sensor for a pin on the stamp? I've been digging around and most of the stuff I come across is designed to detect modulated IR.
I just need to span about 8-12 inch gap and detect when something obscures the beam. I tried using this phototransistor mounted at the end of a black tube (part of a ball point pen cap) to act as a "hood" and used this "high output" IR LED and was not able to get consistent switching using the schematic attached. If someone has a schematic and a part # and a value for the resistor handy, I'd appreciate it!
Vern
Post Edited (Vern) : 8/1/2005 11:25:40 PM GMT
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're Senior Systems Engineer | obviously incompetent so why are we Texas Information Services | paying you? Of course,if the network http://www.txis.com | is up, then we obviously don't need Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
Jon Williams
http://www.reconnsworld.com/ir_ultrasonic_basicirdetectemit.html
Thanx! I bought some new parts today at Rat Shack and will rebuild this circuit using those values and see what I get. COuld just be the parts I had on hand were old/damaged.. We'll see.
Vern
The idea of this circuit was to amplify the weak peripheral signals. In your case,
just a basic IR amplifier.
... I don't think you will need the last stage of this circuit using the 74HC14.
Beau Schwabe
IC Layout Engineer
Wow! Thats above and beyond! Thanx!
Vern
Just an FYI.... You can edit your own posts by clicking on the symbol (upper right) that looks like a pencil.
Likewise you can also 'delete' your own posts by clicking on the "X" symbol.
In Edit mode you can update schematics, text, etc.
Beau Schwabe
IC Layout Engineer
I came across·this·circuit http://home.cogeco.ca/~rpaisley4/DccBODvt5.html·while investigating ways to improve the performance of the IR circuits I·use in my projects. My thought is to replace transistors Q1 and Q2 with the IR detector transistor. The added benefit of this circuit is that it helps to eliminate signal bounce on the input pin·of the BS2. Currently,·the "one shot" functionality has to be implemented in my BS2 code. I have not yet built this circuit with my intended modification.
This last thought is beyond your requirements statement but·what comes to mind is using garage door opener sensors. http://www.genie-garage-door-openers.com/genie_safe.htm·. My garage has a double wide door and the sensors work flawlessly even when in direct sunlight. Not sure what the output of the receiver looks like but it might be interesting to investigate.
Don Buczynski
http://www.buczynski.com
Short
