555 timer circuit not work
This relates to a previous topic from Parallax Forums>Public Forums>Stamps in Class> Ir remote control w/ BS2.
On /17/2005 Andy Lindsay posted a circut to transmit ir with a 555 timer. He also attatched a test frequency program and a test JVC transmit program.
I cannot get the circuit to work! i.e. cannot get it to tune or transmit.
Have done the following to no avail:
triple cked circuit
changed out every component with another one
used a separate 5v source for +5v other than VDD
changed out the 470 ohm and 1K resistors for 10K pot as suggested
I subsituted a visible led for the irt led to se if it would flicker with the pulsout's in the transmit program and it does not.
therefore must conclude that the circuit is not transmitting the pulsout(the led does flicker on a different 555 ir transmit circuit that was in BS1 ap note and also infrared weekend ap note for the bs2).
Has anyone worked with this circuit that might have some suggestions where I am going wrong?
triple cked circuit
Post Edited (Philip Gamblin) : 7/24/2005 5:36:22 PM GMT
I shall do this or go to a whole new protoboard next; unless someone has another suggestion that solves this.
John Bell
In one of your posts you mentioned the following, among other things you'd done:
"used a separate 5v source for +5v other than VDD". When you did that, did you remember to tie all the grounds together to provide a common ground path?
Bruce Bates
I'm sorry the circuit isn't working. I think I still have that one built up at the office. If so, I'll send you a digital photo.
Andy
