the need for speed
hi
i am controlling 6 daisy-chained max7219s, via an external application, written in Processing. The thing is, the data coming in is comnig in really slowly. Would appreciate it if anyone had any ideas as to why?
Could it be because i'm sending 2 wait strings (the "*"'s)? But without them it doesn't seem to work.
also, i have tried sending other data than binary to the BS, but can't seem to get it to work....
here's the code:
and here's a snipped from processing:
Post Edited (george miyagi) : 7/24/2005 4:47:48 PM GMT
here's the code:
progPin CON 16 ' The programming PIN
ledCmd VAR BYTE
serStr VAR BYTE(10)
Clock CON 0 ' shift clock to MAX7219
DPin CON 1 ' shift data to MAX7219
Load CON 2 '
'======Constants==========================
Decode CON $09 ' bcd decode
Intensity CON $0A ' brightness
Scan CON $0B ' scan (column) limit
ShutDn CON $0C ' shutdown (1 = on)
Test CON $0F ' display test mode
Yes CON 1
No CON 0
'==========Variables=========================
index VAR NIB ' loop counter
idxOdd VAR index.BIT0 ' is index odd? (1 = yes)
d7219 VAR BYTE ' data for MAX7219
char VAR BYTE ' character ee address
col VAR NIB ' column value
row VAR NIB ' row value
a VAR WORD ' ee pointer
b VAR BYTE
' Baud CON 16468
Baud CON 84
' Baud CON 32
'=====EEPROM Data=============================
'=========Initialization======================================
'++++++This is edited code++++
'++++ LOOKUP index,[noparse][[/noparse]Scan,7,Intensity,7,ShutDn,1],d7219 +++++
LOW Load
Initialize:
DIRL = %111 ' clock, data and load pins
FOR index = 0 TO 5
SHIFTOUT Dpin,Clock,MSBFIRST,[noparse][[/noparse]d7219]
IF idxOdd = No THEN NoLoad
PULSOUT Load,3 ' load parameter
NoLoad:
NEXT
'==========Clear buffers========================================
'DATA
Main:
get_Data:
FOR col = 1 TO 8
SERIN progPin, Baud, [noparse][[/noparse]WAIT ("*"), BIN serStr(0), BIN serStr(1), BIN serStr(2), BIN serStr(3), BIN serStr(4), BIN serStr(5)] ' wait for Comm
FOR b=0 TO 5
SHIFTOUT Dpin,Clock,MSBFIRST,[noparse][[/noparse]col, serStr(b)]
NEXT
PULSOUT Load,3
SEROUT progPin, Baud, ' SEND the serial DATA
NEXT
GOTO Main
for (row=0;row<8;row++){
print (row);
for (matrix=5;matrix>-1;matrix--){
delay(40);
output = (picData[noparse][[/noparse]matrix][noparse][[/noparse]row]);
myPort.write("*");
myPort.write(output);
myPort.write("*");
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
Product web site: www.sxvm.com
"One experiment is worth a thousand theories"
Ammendment:
Hold, that i got it to work without the extra "*" but am still somewhat lacking in speed? how about shifting 16 bits at a time through the serial?
Post Edited (george miyagi) : 7/25/2005 6:03:44 AM GMT
