Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Toddler: Servo Centering (Getting started) P8 from manual. — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Robotics
ausdj
5
2005-07-22 09:57
edited 2005-07-22 14:58
in
Robotics
Replacing the Servo Horns:
"straight as the spline notches allow"
Have run teh centering program.
With both servos the minimum I can get them placed is server degrees from straight across.
Q Does this matter?
7,417
2005-07-22 14:44
edited 2005-07-22 14:44
Ausdj:
Not a problem. You'll make the fine adjustments in your PBASIC code.
dandreae
1,375
2005-07-22 14:58
This is normal, I have built several of the Toddlers and they all line up a hair off center.
It doesn't affect it at all.
If you have any
questions or comments
please feel free to ask.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
Sign In
Register
to comment.
Dave
Dave Andreae
Tech Support
