Simultaneous pin errors
Hi, yes I'm a noob to BS2 but not to programming or electronics.
I've been working with my BS2 using Discovery kit with USB communication.· I'm able to enable one pin at a time for output but unable to enable two or more pins without having an erroneous errors.· Even a simple program to turn on two leds using pins 14 and 15 simultaneously creates erroneous flashing with no apparent pattern.· The program loops even without a loop statement.· Any help is appreciated.
I've unplugged the device to try to reset and pressed the reset button.· Same results each time.· I'm hoping I didn't recieve a bad BS2.· If you need further information I will post as needed.
Thanks in advance.
Greg
Thanks in advance.
Greg
Beau Schwabe
IC Layout Engineer
' {$STAMP BS2} ' {$PBASIC 2.5} OUTH = %00000000 DIRH = %11111111 OUTH = %11100111 PAUSE 1000 OUTH = %10000100 PAUSE 1000 DIRH = %00000000 ENDStamp Pin >----[noparse][[/noparse] 1K]
|>|---- Vss
Jon Williams
For a sanity check try swapping the "0" and "1" in code to see if you get a flashing "1" instead.
What is the rate of flash? (approx)
Are you using a fresh battery?
' {$STAMP BS2} ' {$PBASIC 2.5} OUTH = %00000000 DIRH = %11111111 OUTH = %10000100 PAUSE 1000 OUTH = %11100111 PAUSE 1000 DIRH = %00000000 END▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
Jon Williams
it sounds like the stamp keeps reseting for whatever reason.
DTQ
additional filter capacitors.
Do you have a battery that you can temporarily try instead of the power supply?
Beau Schwabe
IC Layout Engineer
causing the BS2 to go into brownout. At each interval you are increasing the current demand by about 5mA.
This program should find a make or break situation if there is a problem here.
Another thing you could try is an external regulated 5 volt supply connected to pin 21. This will determine
if the on-board regulator has been damaged or not.
' {$STAMP BS2} ' {$PBASIC 2.5} OUTH = %00000000 DIRH = %11111111 TestLoop: DEBUG CLS OUTH = %10000000 DEBUG "1",CR PAUSE 1000 OUTH = %11000000 DEBUG "2",CR PAUSE 1000 OUTH = %11100000 DEBUG "3",CR PAUSE 1000 OUTH = %11110000 DEBUG "4",CR PAUSE 1000 OUTH = %11111000 DEBUG "5",CR PAUSE 1000 OUTH = %11111100 DEBUG "6",CR PAUSE 1000 OUTH = %11111110 DEBUG "7",CR PAUSE 1000 OUTH = %11111111 DEBUG "8",CR PAUSE 1000 GOTO TestLoop DIRH = %00000000 END▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
