Need Assistance: sxkey - PC Communication Error
OS=Windows XP
PC type=Laptop
product=OEMsx
NameSoftware=SX-Key v3.1
VersionNumber=3.1
programmingboard=Robolympics Scrolling LED Med
DetailedProblem
I received the Robolympics Scrolling LED Med kit. I
added the 3 AAA baterries and it starting scrolling characters,
Parallax....
I then started the SX-Key editor v3.1 and loaded the RobOlyCodev2.SBX
file. I hit the run and it compiled and downloaded it to the RobOlympic.
I then wanted to add my out phrase to display, recompiled and
downloaded. It worked, it is now displaying what I have programmed.
I now want to display another phrase, but I am unable to reprogram it.
SXKey - PC Communication Error (Com4).
I also have the SX Tech board and connected the SX-Key to it and was
able to download program to that SX chip.
What is wrong when I connect SXKey to RobOlympic device? I need help.
What should I do?
Thank you for any assistance anybody can provide.
Source Code Below
SourceCode=DEVICE· SX28, OSC4MHZ, TURBO, STACKX, OPTIONX, BOR22
FREQ··· 4_000_000
IRC_CAL IRC_4MHZ
' PRODUCTION CODE FOR ROBOlympics 2005· 07 MARCH 2005· REV 2.0
' RobOlyCode SXB 1_20.SXB
' Designed & Written By David Winchell -- David@Winchell.com
' Modified for SX/B 1.20 By Terry Hitt -- terry@hittconsulting.com
' Special Thanks to:
' Melinda Winchell -- For Hardware design and Manufacturing Consulting
' Ken Gracey·· -- Parallax THANK YOU FOR ALL THE SUPPORT TO MAKE THIS
HAPPEN :-)
' Chip Gracey· -- Parallax for the SX18, SX28, SX52 and more to come :-)
' Doug Pientak -- Parallax for Hardware Design enhancements & PCB Layout
' Jim Carey··· -- Parallax for SX/B Beta Program Intro, Help,
Insperation & being there :-)
' David Calkins for ROBOlympics 2005 !!· :-)
' Variables
Display VAR Byte (15)
NextChr Var Byte (5)
DataChr Var Byte
OffSet· Var Byte
I······ Var Byte
J······ Var Byte
K······ Var Byte
X······ Var Byte
INTERRUPT
ISR_Start:
RC = 0 ··· 'CLEAR DISPLAY OUT TO PREVENT GHOSTING
Inc RA ··· 'INCREMENT COLUM ADDRESS (RA I/O PINS)
RC = Display( RA ) ··· 'LOAD NEW ROW DATA TO RC
ISR_Exit:
RETURNINT 63
' Define Subroutines
Wait_A_Bit·· SUB
StringWriter SUB
Robot······· SUB
PROGRAM Start
' Winning Team Name and Award Level String.
String_Data:
Data "· Mary Kay - Sharon Thiel·· ",0
' PLEASE SEE ASCII CHART AT THE END OF THIS LIST.
'User Defined Data $00-$1F
'Number Data:····· $20-$3F· !"#$%&'()*+,-./0123456789:;<=>?
'UC Aplhabet Data: $40-$5F @ABCDEFGHIJKLMNOPQRSTUVWXYZ[noparse][[/noparse]\]^_
'LC Aplhabet Data: $60-$7f `abcdefghijklmnopqrstuvwxyz{|}~
'Data "!", $22, "#$%&'()*+,-./0123456789:;<=>?"
'Data "@ABCDEFGHIJKLMNOPQRSTUVWXYZ[noparse][[/noparse]\]^_"
'Data "`abcdefghijklmnopqrstuvwxyz{|}~",0
'Data "··· ",0
'Data "·· THE QUICK BROWN FOX JUMPED OVER THE LAZY DOG 0123456789 TIMES
",0
'Data "·· The Quick Brown Fox Jumped Over The Lazy Dog 0123456789 Times
",0
' Program Code
Start:
TRIS_A = %00000000 'SET PORT A TO OUTPUTS
TRIS_B = %00000000 'SET PORT B TO OUTPUTS
TRIS_C = %00000000 'SET PORT C TO OUTPUTS
OPTION = $82
RA = 0
RB = 0
RC = 0
FOR J = 70 TO 127 'SOUND DEMO
·SOUND RB.7,J,2
NEXT 'END SOUND DEMO
Main:
· Robot
· Wait_A_Bit
· StringWriter
· Wait_A_Bit
GoTo Main
' Wait_A_Bit:
Wait_A_Bit:
· Pause 100
Return
' StringWriter:
StringWriter:
For I = 0 to 255
· Read String_Data + I, DataChr
· If DataChr < $01 Goto StringDone
· If DataChr > $1F Goto NotSpecial
· 'Is Special
· DataChr = DataChr * 5
· For J = 0 to 4
··· OffSet = DataChr + J
··· Read Special_Data + OffSet, NextChr(J)
· next
· goto ChrSet
NotSpecial:
· If DataChr > $3F Goto NotNumber
·'Is Number or Symbol
· DataChr = DataChr - $20
· For J = 0 to 4
··· Read Number_Data + OffSet, NextChr(J)
· next
· goto ChrSet
NotNumber:
· If DataChr > $5F Goto NotUpperCase
·'Is Upper Case
· DataChr = DataChr - $40
· For J = 0 to 4
··· Read UC_Aplhabet_Data + OffSet, NextChr(J)
· next
· goto ChrSet
NotUpperCase:
·'Is Lower Case
· DataChr = DataChr - $60
· For J = 0 to 4
··· Read LC_Aplhabet_Data + OffSet, NextChr(J)
· next
ChrSet:
· For x = 0 to 4
··· For J = 0 to 14
····· K = J + 1
····· Display(J) = Display(K)
··· Next
··· Display(15) = NextChr(0)
··· For J = 0 to 3
····· K = J + 1
····· NextChr(J) = NextChr(K)
··· Next
··· Wait_A_Bit
· Next
· For J = 0 to 14
··· K = J + 1
· Next
· Display(15) = %00000000
· Wait_A_Bit
Next
StringDone:
Return
' Robot:
Robot:
For J = 0 TO 9
· For I = 0 to 14
··· READ Robot_01 + I, Display(I)
· Next
· Wait_A_Bit
· For I = 0 to 14
··· READ Robot_00 + I, Display(I)
· Next·
· Wait_A_Bit
· For I = 0 to 14
··· READ Robot_02 + I, Display(I)
· Next
· Wait_A_Bit
· For I = 0 to 14
· Next
· Wait_A_Bit
Next
Return
Robot_00:
DATA· %00000000
DATA· %00000100
DATA· %01110101
DATA· %00011111
DATA· %01110101
DATA· %00000100
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000100
DATA· %01110101
DATA· %00011111
DATA· %01110101
DATA· %00000100
DATA· %00000000
Robot_01:
DATA· %01000000
DATA· %00101000
DATA· %00010101
DATA· %00011111
DATA· %01110101
DATA· %00000010
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00001000
DATA· %01110101
DATA· %00011111
DATA· %00010101
DATA· %00100010
DATA· %01000000
Robot_02:
DATA· %00000000
DATA· %00000010
DATA· %01110101
DATA· %00011111
DATA· %00010101
DATA· %00101000
DATA· %01000000
DATA· %00000000
DATA· %01000000
DATA· %00100010
DATA· %00010101
DATA· %00011111
DATA· %01110101
DATA· %00001000
DATA· %00000000
'Special_Data: $00-$1F· User Defined Symbols
Special_Data:
S00:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S01:
DATA· %00100000
DATA· %01000011
DATA· %01011000
DATA· %01000011
DATA· %00100000
S02:
DATA· %00000011
DATA· %00000111
DATA· %01111100
DATA· %00001100
DATA· %01111111
S03:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S04:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S05:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
SO6:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S07:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S08:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S09:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S10:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S11:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S12:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S13:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S14:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S15:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S16:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S17:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S18:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S19:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S20:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S21:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S22:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S23:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S24:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S25:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S26:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S27:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S28:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S29:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S30:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S31:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
'Number_Data: $20-$3F· !"#$%&'()*+,-./0123456789:;<=>?
Number_Data:
Space:
DATA· %00000000 'Space
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
Exclamation:
DATA· %00000000 '!
DATA· %00000000
DATA· %01001111
DATA· %00000000
DATA· %00000000
DoubleQuote:
DATA· %00000000 '"
DATA· %00000111
DATA· %00000000
DATA· %00000111
DATA· %00000000
PoundSign:
DATA· %00010100 '#
DATA· %01111111
DATA· %00010100
DATA· %01111111
DATA· %00010100
DollarSign:
DATA· %00100100 '$
DATA· %00101010
DATA· %01111111
DATA· %00101010
DATA· %00010010
PercentSign:
DATA· %00100011 '%
DATA· %00010011
DATA· %00001000
DATA· %01100100
DATA· %01100010
AndSign:
DATA· %00110110 '&
DATA· %01001001
DATA· %01010101
DATA· %00100010
DATA· %01010000
SingleQuote:
DATA· %00000000 ''
DATA· %00000101
DATA· %00000011
DATA· %00000000
DATA· %00000000
OpenParenthesis:
DATA· %00000000 '(
DATA· %00011100
DATA· %00100010
DATA· %01000001
DATA· %00000000
CloseParenthesis:
DATA· %00000000 ')
DATA· %01000001
DATA· %00100010
DATA· %00011100
DATA· %00000000
Star:
DATA· %00010100 '*
DATA· %00001000
DATA· %00111110
DATA· %00001000
DATA· %00010100
PlusSign:
DATA· %00001000 '+
DATA· %00001000
DATA· %00111110
DATA· %00001000
DATA· %00001000
Comma:
DATA· %00000000 ',
DATA· %01010000
DATA· %00110000
DATA· %00000000
DATA· %00000000
NegativeSign:
DATA· %00001000 '-
DATA· %00001000
DATA· %00001000
DATA· %00001000
DATA· %00001000
DecmialPoint:
DATA· %00000000 '.
DATA· %01100000
DATA· %01100000
DATA· %00000000
DATA· %00000000
ForwardSlash:
DATA· %00100000 '/
DATA· %00010000
DATA· %00001000
DATA· %00000100
DATA· %00000010
Number_0:
DATA· %00111110 '0
DATA· %01000101
DATA· %01001001
DATA· %01010001
DATA· %00111110
Number_1:
DATA· %00000000 '1
DATA· %01000010
DATA· %01111111
DATA· %01000000
DATA· %00000000
Number_2:
DATA· %01000010 '2
DATA· %01100001
DATA· %01010001
DATA· %01001001
DATA· %01000110
Number_3:
DATA· %00100001 '3
DATA· %01000001
DATA· %01000101
DATA· %01001011
DATA· %00110001
Number_4:
DATA· %00011000 '4
DATA· %00010100
DATA· %00010010
DATA· %01111111
DATA· %00010000
Number_5:
DATA· %00100111 '5
DATA· %01000101
DATA· %01000101
DATA· %01000101
DATA· %00111001
Number_6:
DATA· %00111100 '6
DATA· %01001010
DATA· %01001001
DATA· %01001001
DATA· %00110000
Number_7:
DATA· %00000001 '7
DATA· %01111001
DATA· %00000101
DATA· %00000011
DATA· %00000011
Number_8:
DATA· %00110110 '8
DATA· %01001001
DATA· %01001001
DATA· %01001001
DATA· %00110110
Number_9:
DATA· %00000110 '9
DATA· %01001001
DATA· %01001001
DATA· %00101001
DATA· %00011110
Colon:
DATA· %00000000 ':
DATA· %00110110
DATA· %00110110
DATA· %00000000
DATA· %00000000
Semicolon:
DATA· %00000000 ';
DATA· %01010110
DATA· %00110110
DATA· %00000000
DATA· %00000000
LessThan:
DATA· %00001000 '<
DATA· %00010100
DATA· %00100010
DATA· %01000001
DATA· %00000000
Equal:
DATA· %00010100 '=
DATA· %00010100
DATA· %00010100
DATA· %00010100
DATA· %00010100
GreaterThan:
DATA· %00000000 '>
DATA· %01000001
DATA· %00100010
DATA· %00010100
DATA· %00001000
Question:
DATA· %00000010 '?
DATA· %00000001
DATA· %01010001
DATA· %00001001
DATA· %00000110
'UC_Aplhabet_Data: $40-$5F @ABCDEFGHIJKLMNOPQRSTUVWXYZ[noparse][[/noparse]\]^_
UC_Aplhabet_Data:
AtSign:
DATA· %00110000 '@
DATA· %01001001
DATA· %01111001
DATA· %01000001
DATA· %00111110
UC_Letter_A:
DATA· %01111100 'A
DATA· %00010010
DATA· %00010001
DATA· %00010010
DATA· %01111100
UC_Letter_B:
DATA· %01000001 'B
DATA· %01111111
DATA· %01001001
DATA· %01001001
DATA· %00110110
UC_Letter_C:
DATA· %00111110 'C
DATA· %01000001
DATA· %01000001
DATA· %01000001
DATA· %00100010
UC_Letter_D:
DATA· %01000001 'D
DATA· %01111111
DATA· %01000001
DATA· %01000001
DATA· %00111110
UC_Letter_E:
DATA· %01111111 'E
DATA· %01001001
DATA· %01001001
DATA· %01000001
DATA· %01000001
UC_Letter_F:
DATA· %01111111 'F
DATA· %00001001
DATA· %00001001
DATA· %00000001
DATA· %00000001
UC_Letter_G:
DATA· %00111110 'G
DATA· %01000001
DATA· %01001001
DATA· %01001001
DATA· %00111010
UC_Letter_H:
DATA· %01111111 'H
DATA· %00001000
DATA· %00001000
DATA· %00001000
DATA· %01111111
UC_Letter_I:
DATA· %00000000 'I
DATA· %01000001
DATA· %01111111
DATA· %01000001
DATA· %00000000
UC_Letter_J:
DATA· %00100000 'J
DATA· %01000000
DATA· %01000001
DATA· %00111111
DATA· %00000001
UC_Letter_K:
DATA· %01111111 'K
DATA· %00001000
DATA· %00010100
DATA· %00100010
DATA· %01000001
UC_Letter_L:
DATA· %01111111 'L
DATA· %01000000
DATA· %01000000
DATA· %01000000
DATA· %01000000
UC_Letter_M:
DATA· %01111111 'M
DATA· %00000010
DATA· %00001100
DATA· %00000010
DATA· %01111111
UC_Letter_N:
DATA· %01111111 'N
DATA· %00000010
DATA· %00000100
DATA· %00001000
DATA· %01111111
UC_Letter_O:
DATA· %00111110 'O
DATA· %01000001
DATA· %01000001
DATA· %01000001
DATA· %00111110
UC_Letter_P:
DATA· %01111111 'P
DATA· %00001001
DATA· %00001001
DATA· %00001001
DATA· %00000110
UC_Letter_Q:
DATA· %00111110 'Q
DATA· %01000001
DATA· %01010001
DATA· %00100001
DATA· %01011110
UC_Letter_R:
DATA· %01111111 'R
DATA· %00001001
DATA· %00011001
DATA· %00101001
DATA· %01000110
UC_Letter_S:
DATA· %00100110 'S
DATA· %01001001
DATA· %01001001
DATA· %01001001
DATA· %00110010
UC_Letter_T:
DATA· %00000001 'T
DATA· %00000001
DATA· %01111111
DATA· %00000001
DATA· %00000001
UC_Letter_U:
DATA· %00111111 'U
DATA· %01000000
DATA· %01000000
DATA· %01000000
DATA· %00111111
UC_Letter_V:
DATA· %00000111 'V
DATA· %00011000
DATA· %01100000
DATA· %00011000
DATA· %00000111
UC_Letter_W:
DATA· %01111111 'W
DATA· %00100000
DATA· %00010000
DATA· %00100000
DATA· %01111111
UC_Letter_X:
DATA· %01100011 'X
DATA· %00010100
DATA· %00001000
DATA· %00010100
DATA· %01100011
UC_Letter_Y:
DATA· %00000011 'Y
DATA· %00000100
DATA· %01111000
DATA· %00000100
DATA· %00000011
UC_Letter_Z:
DATA· %01100001 'Z
DATA· %01010001
DATA· %01001001
DATA· %01000101
DATA· %01000011
OpenBracket:
DATA· %00000000 '[noparse][[/noparse]
DATA· %01111111
DATA· %01000001
DATA· %01000001
DATA· %00000000
BackSlash:
DATA· %00000010 '\
DATA· %00000100
DATA· %00001000
DATA· %00010000
DATA· %00100000
CloseBracket:
DATA· %00000000 ']
DATA· %01000001
DATA· %01000001
DATA· %01111111
DATA· %00000000
Caret:
DATA· %00000100 '^
DATA· %00000010
DATA· %00000001
DATA· %00000010
DATA· %00000100
UnderBar:
DATA· %01000000 '_
DATA· %01000000
DATA· %01000000
DATA· %01000000
DATA· %01000000
'LC_Aplhabet_Data: $60-$7f `abcdefghijklmnopqrstuvwxyz{|}~
LC_Aplhabet_Data:
OpeningSingleQuote:
DATA· %00000000 '`
DATA· %00000001
DATA· %00000010
DATA· %00000100
DATA· %00000000
LC_Letter_A:
DATA· %00100000 'a
DATA· %01010100
DATA· %01010100
DATA· %01010100
DATA· %01111000
LC_Letter_B:
DATA· %01111111 'b
DATA· %01001000
DATA· %01001000
DATA· %01001000
DATA· %00110000
LC_Letter_C:
DATA· %00111000 'c
DATA· %01000100
DATA· %01000100
DATA· %01000100
DATA· %01000100
LC_Letter_D:
DATA· %00110000 'd
DATA· %01001000
DATA· %01001000
DATA· %01001000
DATA· %01111111
LC_Letter_E:
DATA· %00111000 'e
DATA· %01010100
DATA· %01010100
DATA· %01010100
DATA· %01011000
LC_Letter_F:
DATA· %00000000 'f
DATA· %00001000
DATA· %01111110
DATA· %00001001
DATA· %00000010
LC_Letter_G:
DATA· %01001000 'g
DATA· %01010100
DATA· %01010100
DATA· %01010100
DATA· %00111100
LC_Letter_H:
DATA· %01111111 'h
DATA· %00001000
DATA· %00001000
DATA· %00001000
DATA· %01110000
LC_Letter_I:
DATA· %00000000 'i
DATA· %00000000
DATA· %01111010
DATA· %00000000
DATA· %00000000
LC_Letter_J:
DATA· %00100000 'j
DATA· %01000000
DATA· %01000000
DATA· %00111101
DATA· %00000000
LC_Letter_K:
DATA· %00000000 'k
DATA· %01111111
DATA· %00010000
DATA· %00101000
DATA· %01000100
LC_Letter_L:
DATA· %00000000 'l
DATA· %01000001
DATA· %01111111
DATA· %01000000
DATA· %00000000
LC_Letter_M:
DATA· %01111100 'm
DATA· %00000100
DATA· %00111000
DATA· %00000100
DATA· %01111100
LC_Letter_N:
DATA· %01111100 'n
DATA· %00001000
DATA· %00000100
DATA· %00000100
DATA· %01111000
LC_Letter_O:
DATA· %00111000 'o
DATA· %01000100
DATA· %01000100
DATA· %01000100
DATA· %00111000
LC_Letter_P:
DATA· %01111100 'p
DATA· %00010100
DATA· %00010100
DATA· %00010100
DATA· %00001000
LC_Letter_Q:
DATA· %00001000 'q
DATA· %00010100
DATA· %00010100
DATA· %00010100
DATA· %01111100
LC_Letter_R:
DATA· %01111100 'r
DATA· %00001000
DATA· %00000100
DATA· %00001000
DATA· %00000000
LC_Letter_S:
DATA· %01001000 's
DATA· %01010100
DATA· %01010100
DATA· %01010100
DATA· %00100100
LC_Letter_T:
DATA· %00000100 't
DATA· %00000100
DATA· %00111111
DATA· %01000100
DATA· %00100100
LC_Letter_U:
DATA· %00111100 'u
DATA· %01000000
DATA· %01000000
DATA· %01000000
DATA· %00111100
LC_Letter_V:
DATA· %00011100 'v
DATA· %00100000
DATA· %01000000
DATA· %00100000
DATA· %00011100
LC_Letter_W:
DATA· %00111100 'w
DATA· %01000000
DATA· %00110000
DATA· %01000000
DATA· %00111100
LC_Letter_X:
DATA· %01000100 'x
DATA· %00101000
DATA· %00010000
DATA· %00101000
DATA· %01000100
LC_Letter_Y:
DATA· %00000100 'y
DATA· %01001000
DATA· %00110000
DATA· %00001000
DATA· %00000100
LC_Letter_Z:
DATA· %01000100 'z
DATA· %01100100
DATA· %01010100
DATA· %01001100
DATA· %01000100
OpeningCurlyBrace:
DATA· %00001000 '{
DATA· %00110110
DATA· %01000001
DATA· %01000001
DATA· %00000000
VerticalLine:
DATA· %00000000 '|
DATA· %00000000
DATA· %01111111
DATA· %00000000
DATA· %00000000
ClosingCurlyBrace:
DATA· %00000000 '}
DATA· %01000001
DATA· %01000001
DATA· %00110110
DATA· %00001000
Tilde:
DATA· %00000100 '~
DATA· %00000010
DATA· %00000010
DATA· %00000010
DATA· %00000001
Delete:
DATA· %01111111 '$7F
DATA· %01000001
DATA· %01000001
DATA· %01000001
DATA· %01111111
' ASCII Character Set
'· Char Dec Hex Description
'· SP·· 32· 20· Space·
'· !··· 33· 21· Exclamation mark·
'· "··· 34· 22· Quotation mark
'· #··· 35· 23· Cross hatch (number sign)·
'· $··· 36· 24· Dollar sign·
'· %··· 37· 25· Percent sign·
'· &··· 38· 26· Ampersand·
'· '··· 39· 27· Closing single quote (apostrophe)·
'· (··· 40· 28· Opening parentheses·
'· )··· 41· 29· Closing parentheses·
'· *··· 42· 2a· Asterisk (star, multiply)·
'· +··· 43· 2b· Plus·
'· ,··· 44· 2c· Comma·
'· -··· 45· 2d· Hyphen, dash, minus·
'· .··· 46· 2e· Period·
'· /··· 47· 2f· Slant (forward slash, divide)·
'· 0··· 48· 30· Zero·
'· 1··· 49· 31· One·
'· 2··· 50· 32· Two·
'· 3··· 51· 33· Three·
'· 4··· 52· 34· Four·
'· 5··· 53· 35· Five·
'· 6··· 54· 36· Six·
'· 7··· 55· 37· Seven·
'· 8··· 56· 38· Eight·
'· 9··· 57· 39· Nine·
'· :··· 58· 3a· Colon·
'· ;··· 59· 3b· Semicolon·
'· <··· 60· 3c· Less than sign
'· =··· 61· 3d· Equals sign·
'· >··· 62· 3e· Greater than sign
'· ?··· 63· 3f· Question mark·
'· @··· 64· 40· At-sign·
'· A··· 65· 41· Uppercase A·
'· B··· 66· 42· Uppercase B·
'· C··· 67· 43· Uppercase C·
'· D··· 68· 44· Uppercase D·
'· E··· 69· 45· Uppercase E·
'· F··· 70· 46· Uppercase F·
'· G··· 71· 47· Uppercase G·
'· H··· 72· 48· Uppercase H·
'· I··· 73· 49· Uppercase I·
'· J··· 74· 4a· Uppercase J·
'· K··· 75· 4b· Uppercase K·
'· L··· 76· 4c· Uppercase L·
'· M··· 77· 4d· Uppercase M·
'· N··· 78· 4e· Uppercase N·
'· O··· 79· 4f· Uppercase O·
'· P··· 80· 50· Uppercase P·
'· Q··· 81· 51· Uppercase Q·
'· R··· 82· 52· Uppercase R·
'· S··· 83· 53· Uppercase S·
'· T··· 84· 54· Uppercase T·
'· U··· 85· 55· Uppercase U·
'· V··· 86· 56· Uppercase V·
'· W··· 87· 57· Uppercase W·
'· X··· 88· 58· Uppercase X·
'· Y··· 89· 59· Uppercase Y·
'· Z··· 90· 5a· Uppercase Z·
'· [noparse][[/noparse]··· 91· 5b· Opening square bracket·
'· \··· 92· 5c· Reverse slant (Backslash)·
'· ]··· 93· 5d· Closing square bracket·
'· ^··· 94· 5e· Caret (Circumflex)·
'· _··· 95· 5f· Underscore·
'· `··· 96· 60· Opening single quote·
'· a··· 97· 61· Lowercase a·
'· b··· 98· 62· Lowercase b·
'· c··· 99· 63· Lowercase c·
'· d·· 100· 64· Lowercase d·
'· e·· 101· 65· Lowercase e·
'· f·· 102· 66· Lowercase f·
'· g·· 103· 67· Lowercase g·
'· h·· 104· 68· Lowercase h·
'· i·· 105· 69· Lowercase i·
'· j·· 106· 6a· Lowercase j·
'· k·· 107· 6b· Lowercase k·
'· l·· 108· 6c· Lowercase l·
'· m·· 109· 6d· Lowercase m·
'· n·· 110· 6e· Lowercase n·
'· o·· 111· 6f· Lowercase o·
'· p·· 112· 70· Lowercase p·
'· q·· 113· 71· Lowercase q·
'· r·· 114· 72· Lowercase r·
'· s·· 115· 73· Lowercase s·
'· t·· 116· 74· Lowercase t·
'· u·· 117· 75· Lowercase u·
'· v·· 118· 76· Lowercase v·
'· w·· 119· 77· Lowercase w·
'· x·· 120· 78· Lowercase x·
'· y·· 121· 79· Lowercase y·
'· z·· 122· 7a· Lowercase z·
'· {·· 123· 7b· Opening curly brace·
'· |·· 124· 7c· Vertical line·
'· }·· 125· 7d· Closing curly brace·
'· ~·· 126· 7e· Tilde (approximate)·
'· DEL 177· 7f· Delete (rubout), cross-hatch box
PC type=Laptop
product=OEMsx
VersionNumber=3.1
DetailedProblem
Parallax....
What should I do?
Source Code Below
FREQ··· 4_000_000
IRC_CAL IRC_4MHZ
HAPPEN :-)
' Variables
DataChr Var Byte
OffSet· Var Byte
I······ Var Byte
J······ Var Byte
K······ Var Byte
X······ Var Byte
INTERRUPT
ISR_Start:
ISR_Exit:
RETURNINT 63
Wait_A_Bit·· SUB
StringWriter SUB
Robot······· SUB
PROGRAM Start
String_Data:
'Data "··· ",0
",0
",0
' Program Code
Start:
OPTION = $82
RA = 0
RB = 0
RC = 0
·SOUND RB.7,J,2
Main:
· Robot
· Wait_A_Bit
· StringWriter
· Wait_A_Bit
GoTo Main
' Wait_A_Bit:
Wait_A_Bit:
· Pause 100
Return
' StringWriter:
StringWriter:
For I = 0 to 255
· 'Is Special
· For J = 0 to 4
· next
· goto ChrSet
NotSpecial:
· For J = 0 to 4
· next
· goto ChrSet
NotNumber:
·'Is Upper Case
· For J = 0 to 4
· next
· goto ChrSet
NotUpperCase:
·'Is Lower Case
· For J = 0 to 4
· next
ChrSet:
· For x = 0 to 4
··· For J = 0 to 14
····· K = J + 1
··· Next
··· For J = 0 to 3
····· K = J + 1
··· Next
··· Wait_A_Bit
· Next
· For J = 0 to 14
··· K = J + 1
· Next
· Wait_A_Bit
Next
StringDone:
Return
' Robot:
Robot:
For J = 0 TO 9
· For I = 0 to 14
· Next
· Wait_A_Bit
· For I = 0 to 14
· Next·
· Wait_A_Bit
· For I = 0 to 14
· Next
· Wait_A_Bit
· For I = 0 to 14
· Next
· Wait_A_Bit
Next
Return
Robot_00:
DATA· %00000000
DATA· %00000100
DATA· %01110101
DATA· %00011111
DATA· %01110101
DATA· %00000100
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000100
DATA· %01110101
DATA· %00011111
DATA· %01110101
DATA· %00000100
DATA· %00000000
Robot_01:
DATA· %01000000
DATA· %00101000
DATA· %00010101
DATA· %00011111
DATA· %01110101
DATA· %00000010
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00001000
DATA· %01110101
DATA· %00011111
DATA· %00010101
DATA· %00100010
DATA· %01000000
Robot_02:
DATA· %00000000
DATA· %00000010
DATA· %01110101
DATA· %00011111
DATA· %00010101
DATA· %00101000
DATA· %01000000
DATA· %00000000
DATA· %01000000
DATA· %00100010
DATA· %00010101
DATA· %00011111
DATA· %01110101
DATA· %00001000
DATA· %00000000
Special_Data:
S00:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S01:
DATA· %00100000
DATA· %01000011
DATA· %01011000
DATA· %01000011
DATA· %00100000
S02:
DATA· %00000011
DATA· %00000111
DATA· %01111100
DATA· %00001100
DATA· %01111111
S03:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S04:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S05:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
SO6:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S07:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S08:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S09:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S10:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S11:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S12:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S13:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S14:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S15:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S16:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S17:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S18:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S19:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S20:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S21:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S22:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S23:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S24:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S25:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S26:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S27:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S28:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S29:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S30:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
S31:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
Number_Data:
Space:
DATA· %00000000
DATA· %00000000
DATA· %00000000
DATA· %00000000
Exclamation:
DATA· %00000000 '!
DATA· %00000000
DATA· %01001111
DATA· %00000000
DATA· %00000000
DoubleQuote:
DATA· %00000000 '"
DATA· %00000111
DATA· %00000000
DATA· %00000111
DATA· %00000000
PoundSign:
DATA· %00010100 '#
DATA· %01111111
DATA· %00010100
DATA· %01111111
DATA· %00010100
DollarSign:
DATA· %00100100 '$
DATA· %00101010
DATA· %01111111
DATA· %00101010
DATA· %00010010
PercentSign:
DATA· %00100011 '%
DATA· %00010011
DATA· %00001000
DATA· %01100100
DATA· %01100010
AndSign:
DATA· %00110110 '&
DATA· %01001001
DATA· %01010101
DATA· %00100010
DATA· %01010000
SingleQuote:
DATA· %00000000 ''
DATA· %00000101
DATA· %00000011
DATA· %00000000
DATA· %00000000
OpenParenthesis:
DATA· %00000000 '(
DATA· %00011100
DATA· %00100010
DATA· %01000001
DATA· %00000000
CloseParenthesis:
DATA· %00000000 ')
DATA· %01000001
DATA· %00100010
DATA· %00011100
DATA· %00000000
Star:
DATA· %00010100 '*
DATA· %00001000
DATA· %00111110
DATA· %00001000
DATA· %00010100
PlusSign:
DATA· %00001000 '+
DATA· %00001000
DATA· %00111110
DATA· %00001000
DATA· %00001000
Comma:
DATA· %00000000 ',
DATA· %01010000
DATA· %00110000
DATA· %00000000
DATA· %00000000
NegativeSign:
DATA· %00001000 '-
DATA· %00001000
DATA· %00001000
DATA· %00001000
DATA· %00001000
DecmialPoint:
DATA· %00000000 '.
DATA· %01100000
DATA· %01100000
DATA· %00000000
DATA· %00000000
ForwardSlash:
DATA· %00100000 '/
DATA· %00010000
DATA· %00001000
DATA· %00000100
DATA· %00000010
Number_0:
DATA· %00111110 '0
DATA· %01000101
DATA· %01001001
DATA· %01010001
DATA· %00111110
Number_1:
DATA· %00000000 '1
DATA· %01000010
DATA· %01111111
DATA· %01000000
DATA· %00000000
Number_2:
DATA· %01000010 '2
DATA· %01100001
DATA· %01010001
DATA· %01001001
DATA· %01000110
Number_3:
DATA· %00100001 '3
DATA· %01000001
DATA· %01000101
DATA· %01001011
DATA· %00110001
Number_4:
DATA· %00011000 '4
DATA· %00010100
DATA· %00010010
DATA· %01111111
DATA· %00010000
Number_5:
DATA· %00100111 '5
DATA· %01000101
DATA· %01000101
DATA· %01000101
DATA· %00111001
Number_6:
DATA· %00111100 '6
DATA· %01001010
DATA· %01001001
DATA· %01001001
DATA· %00110000
Number_7:
DATA· %00000001 '7
DATA· %01111001
DATA· %00000101
DATA· %00000011
DATA· %00000011
Number_8:
DATA· %00110110 '8
DATA· %01001001
DATA· %01001001
DATA· %01001001
DATA· %00110110
Number_9:
DATA· %00000110 '9
DATA· %01001001
DATA· %01001001
DATA· %00101001
DATA· %00011110
Colon:
DATA· %00000000 ':
DATA· %00110110
DATA· %00110110
DATA· %00000000
DATA· %00000000
Semicolon:
DATA· %00000000 ';
DATA· %01010110
DATA· %00110110
DATA· %00000000
DATA· %00000000
LessThan:
DATA· %00001000 '<
DATA· %00010100
DATA· %00100010
DATA· %01000001
DATA· %00000000
Equal:
DATA· %00010100 '=
DATA· %00010100
DATA· %00010100
DATA· %00010100
DATA· %00010100
GreaterThan:
DATA· %00000000 '>
DATA· %01000001
DATA· %00100010
DATA· %00010100
DATA· %00001000
Question:
DATA· %00000010 '?
DATA· %00000001
DATA· %01010001
DATA· %00001001
DATA· %00000110
UC_Aplhabet_Data:
AtSign:
DATA· %00110000 '@
DATA· %01001001
DATA· %01111001
DATA· %01000001
DATA· %00111110
UC_Letter_A:
DATA· %01111100 'A
DATA· %00010010
DATA· %00010001
DATA· %00010010
DATA· %01111100
UC_Letter_B:
DATA· %01000001 'B
DATA· %01111111
DATA· %01001001
DATA· %01001001
DATA· %00110110
UC_Letter_C:
DATA· %00111110 'C
DATA· %01000001
DATA· %01000001
DATA· %01000001
DATA· %00100010
UC_Letter_D:
DATA· %01000001 'D
DATA· %01111111
DATA· %01000001
DATA· %01000001
DATA· %00111110
UC_Letter_E:
DATA· %01111111 'E
DATA· %01001001
DATA· %01001001
DATA· %01000001
DATA· %01000001
UC_Letter_F:
DATA· %01111111 'F
DATA· %00001001
DATA· %00001001
DATA· %00000001
DATA· %00000001
UC_Letter_G:
DATA· %00111110 'G
DATA· %01000001
DATA· %01001001
DATA· %01001001
DATA· %00111010
UC_Letter_H:
DATA· %01111111 'H
DATA· %00001000
DATA· %00001000
DATA· %00001000
DATA· %01111111
UC_Letter_I:
DATA· %00000000 'I
DATA· %01000001
DATA· %01111111
DATA· %01000001
DATA· %00000000
UC_Letter_J:
DATA· %00100000 'J
DATA· %01000000
DATA· %01000001
DATA· %00111111
DATA· %00000001
UC_Letter_K:
DATA· %01111111 'K
DATA· %00001000
DATA· %00010100
DATA· %00100010
DATA· %01000001
UC_Letter_L:
DATA· %01111111 'L
DATA· %01000000
DATA· %01000000
DATA· %01000000
DATA· %01000000
UC_Letter_M:
DATA· %01111111 'M
DATA· %00000010
DATA· %00001100
DATA· %00000010
DATA· %01111111
UC_Letter_N:
DATA· %01111111 'N
DATA· %00000010
DATA· %00000100
DATA· %00001000
DATA· %01111111
UC_Letter_O:
DATA· %00111110 'O
DATA· %01000001
DATA· %01000001
DATA· %01000001
DATA· %00111110
UC_Letter_P:
DATA· %01111111 'P
DATA· %00001001
DATA· %00001001
DATA· %00001001
DATA· %00000110
UC_Letter_Q:
DATA· %00111110 'Q
DATA· %01000001
DATA· %01010001
DATA· %00100001
DATA· %01011110
UC_Letter_R:
DATA· %01111111 'R
DATA· %00001001
DATA· %00011001
DATA· %00101001
DATA· %01000110
UC_Letter_S:
DATA· %00100110 'S
DATA· %01001001
DATA· %01001001
DATA· %01001001
DATA· %00110010
UC_Letter_T:
DATA· %00000001 'T
DATA· %00000001
DATA· %01111111
DATA· %00000001
DATA· %00000001
UC_Letter_U:
DATA· %00111111 'U
DATA· %01000000
DATA· %01000000
DATA· %01000000
DATA· %00111111
UC_Letter_V:
DATA· %00000111 'V
DATA· %00011000
DATA· %01100000
DATA· %00011000
DATA· %00000111
UC_Letter_W:
DATA· %01111111 'W
DATA· %00100000
DATA· %00010000
DATA· %00100000
DATA· %01111111
UC_Letter_X:
DATA· %01100011 'X
DATA· %00010100
DATA· %00001000
DATA· %00010100
DATA· %01100011
UC_Letter_Y:
DATA· %00000011 'Y
DATA· %00000100
DATA· %01111000
DATA· %00000100
DATA· %00000011
UC_Letter_Z:
DATA· %01100001 'Z
DATA· %01010001
DATA· %01001001
DATA· %01000101
DATA· %01000011
OpenBracket:
DATA· %01111111
DATA· %01000001
DATA· %01000001
DATA· %00000000
BackSlash:
DATA· %00000010 '\
DATA· %00000100
DATA· %00001000
DATA· %00010000
DATA· %00100000
CloseBracket:
DATA· %00000000 ']
DATA· %01000001
DATA· %01000001
DATA· %01111111
DATA· %00000000
Caret:
DATA· %00000100 '^
DATA· %00000010
DATA· %00000001
DATA· %00000010
DATA· %00000100
UnderBar:
DATA· %01000000 '_
DATA· %01000000
DATA· %01000000
DATA· %01000000
DATA· %01000000
LC_Aplhabet_Data:
OpeningSingleQuote:
DATA· %00000000 '`
DATA· %00000001
DATA· %00000010
DATA· %00000100
DATA· %00000000
LC_Letter_A:
DATA· %00100000 'a
DATA· %01010100
DATA· %01010100
DATA· %01010100
DATA· %01111000
LC_Letter_B:
DATA· %01111111 'b
DATA· %01001000
DATA· %01001000
DATA· %01001000
DATA· %00110000
LC_Letter_C:
DATA· %00111000 'c
DATA· %01000100
DATA· %01000100
DATA· %01000100
DATA· %01000100
LC_Letter_D:
DATA· %00110000 'd
DATA· %01001000
DATA· %01001000
DATA· %01001000
DATA· %01111111
LC_Letter_E:
DATA· %00111000 'e
DATA· %01010100
DATA· %01010100
DATA· %01010100
DATA· %01011000
LC_Letter_F:
DATA· %00000000 'f
DATA· %00001000
DATA· %01111110
DATA· %00001001
DATA· %00000010
LC_Letter_G:
DATA· %01001000 'g
DATA· %01010100
DATA· %01010100
DATA· %01010100
DATA· %00111100
LC_Letter_H:
DATA· %01111111 'h
DATA· %00001000
DATA· %00001000
DATA· %00001000
DATA· %01110000
LC_Letter_I:
DATA· %00000000 'i
DATA· %00000000
DATA· %01111010
DATA· %00000000
DATA· %00000000
LC_Letter_J:
DATA· %00100000 'j
DATA· %01000000
DATA· %01000000
DATA· %00111101
DATA· %00000000
LC_Letter_K:
DATA· %00000000 'k
DATA· %01111111
DATA· %00010000
DATA· %00101000
DATA· %01000100
LC_Letter_L:
DATA· %00000000 'l
DATA· %01000001
DATA· %01111111
DATA· %01000000
DATA· %00000000
LC_Letter_M:
DATA· %01111100 'm
DATA· %00000100
DATA· %00111000
DATA· %00000100
DATA· %01111100
LC_Letter_N:
DATA· %01111100 'n
DATA· %00001000
DATA· %00000100
DATA· %00000100
DATA· %01111000
LC_Letter_O:
DATA· %00111000 'o
DATA· %01000100
DATA· %01000100
DATA· %01000100
DATA· %00111000
LC_Letter_P:
DATA· %01111100 'p
DATA· %00010100
DATA· %00010100
DATA· %00010100
DATA· %00001000
LC_Letter_Q:
DATA· %00001000 'q
DATA· %00010100
DATA· %00010100
DATA· %00010100
DATA· %01111100
LC_Letter_R:
DATA· %01111100 'r
DATA· %00001000
DATA· %00000100
DATA· %00001000
DATA· %00000000
LC_Letter_S:
DATA· %01001000 's
DATA· %01010100
DATA· %01010100
DATA· %01010100
DATA· %00100100
LC_Letter_T:
DATA· %00000100 't
DATA· %00000100
DATA· %00111111
DATA· %01000100
DATA· %00100100
LC_Letter_U:
DATA· %00111100 'u
DATA· %01000000
DATA· %01000000
DATA· %01000000
DATA· %00111100
LC_Letter_V:
DATA· %00011100 'v
DATA· %00100000
DATA· %01000000
DATA· %00100000
DATA· %00011100
LC_Letter_W:
DATA· %00111100 'w
DATA· %01000000
DATA· %00110000
DATA· %01000000
DATA· %00111100
LC_Letter_X:
DATA· %01000100 'x
DATA· %00101000
DATA· %00010000
DATA· %00101000
DATA· %01000100
LC_Letter_Y:
DATA· %00000100 'y
DATA· %01001000
DATA· %00110000
DATA· %00001000
DATA· %00000100
LC_Letter_Z:
DATA· %01000100 'z
DATA· %01100100
DATA· %01010100
DATA· %01001100
DATA· %01000100
OpeningCurlyBrace:
DATA· %00001000 '{
DATA· %00110110
DATA· %01000001
DATA· %01000001
DATA· %00000000
VerticalLine:
DATA· %00000000 '|
DATA· %00000000
DATA· %01111111
DATA· %00000000
DATA· %00000000
ClosingCurlyBrace:
DATA· %00000000 '}
DATA· %01000001
DATA· %01000001
DATA· %00110110
DATA· %00001000
Tilde:
DATA· %00000100 '~
DATA· %00000010
DATA· %00000010
DATA· %00000010
DATA· %00000001
Delete:
DATA· %01000001
DATA· %01000001
DATA· %01000001
DATA· %01111111
Once you have the Robomedal programmed, you can remove the wires and reinstall the batteries. The Robomedal will continue to run until the battery voltage drops to around 3V.
I hooked up a 5 volt power supply and now it works.
Thank you
