Servo Pulse Train
As I am transitioning from the BASIC Stamp to the Javelin Stamp, I'm trying to convert my code around the PWM VP. If I have the following:
PWM servoL = new PWM(CPU.pin1, 50, 50);
and it spins the axle clockwise, how do I get the servo on the right (servoR), to spin its axle counter-clockwise?
Thanks!
Thanks!
I'm not sure how to affect the duty cycle of the PWM so I can have a servo go from forward to reverse. I can do it fine on the BASIC Stamp but I'm having difficulty with the Javelin Stamp. Can someone help me with some insight on this?
Thanks.
Jon Williams
Thanks for your response. I know that 1.5ms is center. Where I'm having a challenge is in the Java code. PWM is extended from VirtualPeripheral. The slice I'm alloted is 8.25ms and the documentation is not clear how much of a fraction of that slice should be set high/low in order for me to reverse the servo. This is what is confusing to me. If the documentation was just a tad clearer, I know I could solve this riddle.
If you look in the Projects\Examples\Manual_v1_0 folder you should find this servo demo:
// Program Listing 4.5 - Basic Servo Control import stamp.core.*; public class ServoControl { static PWM servo = new PWM(CPU.pin12,173,2304); public static void main() { System.out.println("Welcome to Servo Control: "); System.out.println(" r - right"); System.out.println(" l - left"); System.out.println(" c - center"); while (true) { switch ( Terminal.getChar() ) { case 'r': servo.update(130,2304); break; case 'l': servo.update(220,2304); break; case 'c': servo.update(173,2304); break; } } } }Note that the Parallax CR servos are really best for Javelin apps as they allow access to the centering pot -- that allows you to calibrate them to the center (stop) value output by the Javelin.
Jon Williams
I see where I went wrong: like an idiot I misread microseconds for milliseconds.
'Nuff said.
Thanks, again.
