Floating BS2 Pins.
Clock Loop
IF not being used, the pins on the BS2, should they be left to float? I am using all Input/out pins. (so none of those will float)
I am just making a circuit that will only run the program, and not do anything else.
I have an external 5v regulator I plan to use (connecting to the bs2's VDD)
Should all these pins float?
Vin
RST
Sout
Sin ATN
Vin
RST
Sout
Sin ATN
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
