Basic Stamp Case help
GRR this is frustrating.· Im trying to run a remote program through my robot but when I run the program it says "Expected statements to follow previous 'CASE'".· It highlights Endselect when it says that but Im just confused.· Can anyone help me?
In the modified code below, the variable is "gear" and depending on the state of gear I take some action. In this case I left only commented debug statements to make the example easy to follow.
If gear is $C0 then do some stuff related to 1st gear
If gear is $A8 then do some stuff related to 2nd gear
etc.
SELECT gear CASE $C0 'DEBUG "1st gear ", CR CASE $A8 'DEBUG "2nd gear ", CR CASE $D8 'DEBUG "3rd gear ", CR CASE $F0 'DEBUG "4th gear ", CR CASE $90 'DEBUG "4th gear ", CR ENDSELECT▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Ken
Post Edited (KenM) : 7/1/2005 2:22:04 PM GMT
'Version 030217
'{$STAMP BS2}
'{$PBASIC 2.5}
' WORKSHOP 4 - LAB 8
' main routine '
DEBUG "Reset",CR
DO WHILE 1 'loop forever
GOSUB getcode 'get remote signal code
DEBUG ?receive 'display which code was pressed
'and then perform an action
SELECT receive
CASE 770
'up button pressed
FOR x = 0 TO 9
PULSOUT 14, 750-150
PULSOUT 15, 750+150
PAUSE 20
NEXT
CASE 962
'down button pressed
FOR x = 0 TO 9
PULSOUT 14, 750+150
PULSOUT 15, 750-150
PAUSE 20
NEXT
CASE 834
'left button pressed
FOR x = 0 TO 9
PULSOUT 14, 750+150
PULSOUT 15, 750+150
PAUSE 20
NEXT
CASE 898
'right button pressed
FOR x = 0 TO 9
PULSOUT 14, 750-150
PULSOUT 15, 750-150
PAUSE 20
NEXT
CASE 850
'power button pressed
END
CASE 594
'mute button pressed
FREQOUT 1, 750, 1046 'C
FREQOUT 1, 750, 1567 'G
FREQOUT 1, 250, 1396 'F
FREQOUT 1, 250, 1318 'E
FREQOUT 1, 250, 1174 'D
FREQOUT 1, 700, 2092 'C
FREQOUT 1, 700, 1567 'G
FREQOUT 1, 700, 1174 'D
CASE 930
ENDSELECT <---There is the problem
LOOP
'subroutine for scanning for remote signal '
' do not change '
' hook up IR receiver to pin 0 '
getcode:
RECEIVE VAR Word
COPY VAR Word
IR_IN CON 0 'change this number
IR_Pin VAR IN0 'and this number
buffer VAR Word(4)
x VAR Byte
bitcount VAR Nib
beats VAR Nib
copy = receive
wait_for_clear:
IF IR_PIN = 0 THEN wait_for_clear
wait_for_signal:
IF IR_PIN = 1 THEN wait_for_signal
buffer.BIT0(0) = ~IR_PIN
buffer.BIT0(1) = ~IR_PIN
buffer.BIT0(2) = ~IR_PIN
buffer.BIT0(3) = ~IR_PIN
buffer.BIT0(4) = ~IR_PIN
buffer.BIT0(5) = ~IR_PIN
buffer.BIT0(6) = ~IR_PIN
buffer.BIT0(7) = ~IR_PIN
buffer.BIT0(8) = ~IR_PIN
buffer.BIT0(9) = ~IR_PIN
buffer.BIT0(10) = ~IR_PIN
buffer.BIT0(11) = ~IR_PIN
buffer.BIT0(12) = ~IR_PIN
buffer.BIT0(13) = ~IR_PIN
buffer.BIT0(14) = ~IR_PIN
buffer.BIT0(15) = ~IR_PIN
buffer.BIT0(16) = ~IR_PIN
buffer.BIT0(17) = ~IR_PIN
buffer.BIT0(18) = ~IR_PIN
buffer.BIT0(19) = ~IR_PIN
buffer.BIT0(20) = ~IR_PIN
buffer.BIT0(21) = ~IR_PIN
buffer.BIT0(22) = ~IR_PIN
buffer.BIT0(23) = ~IR_PIN
buffer.BIT0(24) = ~IR_PIN
buffer.BIT0(25) = ~IR_PIN
buffer.BIT0(26) = ~IR_PIN
buffer.BIT0(27) = ~IR_PIN
buffer.BIT0(28) = ~IR_PIN
buffer.BIT0(29) = ~IR_PIN
buffer.BIT0(30) = ~IR_PIN
buffer.BIT0(31) = ~IR_PIN
buffer.BIT0(32) = ~IR_PIN
buffer.BIT0(33) = ~IR_PIN
buffer.BIT0(34) = ~IR_PIN
buffer.BIT0(35) = ~IR_PIN
buffer.BIT0(36) = ~IR_PIN
buffer.BIT0(37) = ~IR_PIN
buffer.BIT0(38) = ~IR_PIN
buffer.BIT0(39) = ~IR_PIN
buffer.BIT0(40) = ~IR_PIN
buffer.BIT0(41) = ~IR_PIN
buffer.BIT0(42) = ~IR_PIN
buffer.BIT0(43) = ~IR_PIN
buffer.BIT0(44) = ~IR_PIN
buffer.BIT0(45) = ~IR_PIN
buffer.BIT0(46) = ~IR_PIN
buffer.BIT0(47) = ~IR_PIN
buffer.BIT0(48) = ~IR_PIN
buffer.BIT0(49) = ~IR_PIN
buffer.BIT0(50) = ~IR_PIN
buffer.BIT0(51) = ~IR_PIN
buffer.BIT0(52) = ~IR_PIN
buffer.BIT0(53) = ~IR_PIN
buffer.BIT0(54) = ~IR_PIN
buffer.BIT0(55) = ~IR_PIN
buffer.BIT0(56) = ~IR_PIN
buffer.BIT0(57) = ~IR_PIN
buffer.BIT0(58) = ~IR_PIN
buffer.BIT0(59) = ~IR_PIN
buffer.BIT0(60) = ~IR_PIN
buffer.BIT0(61) = ~IR_PIN
buffer.BIT0(62) = ~IR_PIN
buffer.BIT0(63) = ~IR_PIN
receive = 0
bitcount = 0
cutoff CON 3 'length of pulse to count as 1
FOR x = 1 TO 63
buffer.BIT0(x) = ~buffer.BIT0(x)
IF buffer.BIT0(x) <> 0 THEN
IF buffer.BIT0(x-1) <> 1 THEN
'0 to 1 transition (end of pulse)
beats = (beats - cutoff) >> 15
receive = (receive << 1) | beats
bitcount = bitcount + 1
ENDIF
ELSE
'pulse... count beats
IF buffer.BIT0(x-1) <> 0 THEN
beats = 0
ENDIF
beats = beats + 1 'add a beat
ENDIF
NEXT
receive = ~(receive << (16 - bitcount & 15))
receive = receive >> 6
IF receive <> copy THEN getcode 'make sure code is received properly
RETURN
·· According to your code, you have no commands following the last CASE statement, prior to the ENDSELECT.· You must have·instructions following any CASE statement, or·the command is·incomplete.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 7/1/2005 2:28:39 PM GMT
If it's not going to be used at the moment, and you want to leave the CASE 930 as a placeholder, just add a PAUSE 1 in there or some other harmless command, otherwise just delete it. A null CASE statement has no meaning.
Bruce Bates
Post Edited (Bruce Bates) : 7/1/2005 2:51:21 PM GMT
