Need source for 25MHz resonator for SX28
Bean
Does anyone know of a 25MHz resonator that will work with the SX28 ?
I bought some from digikey, but they turned out to be 3rd overtone and they won't work.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
Product web site: www.sxvm.com
"What's the difference between ignorance and apathy ?"
"I don't know, and I don't care."
Bean.
I once also had the need for "odd" clock frequencies. I have used crystals instead of resonators as they are available for many different frequencies and they are not too expensive either.
Greetings from Germany,
G
Fox semiconductor makes SMD oscillators, but finding a distributor that offers easy purchase (digikey, mouser, etc) could be a challange. Findchips shows Harry Krantz and Rydek have stock, but they use the old quote system of ordering.
I saw some xtals on digikey, and that is probably the way I will go.
I can't believe they make 20MHz and 50MHz but not 25mHz Arrrg
Of course 20MHz is not quite fast enough, 50MHz will work, but uses about twice the current....
Bean.
for the SX48BD, don't know the type though.
regards peter
I use 3rd Overtone 50Mhz resonators all the time ( with 1M ohm resistor across OSC1 and OSC2 )
and they always worked fine....
William
I will try it again. I don't think I had the resistor across it when I tried it.
Bean.
It's been a few days.
Did it work ?
thanks
cb
I haven't had a chance to try it again. I'm working on another project at the moment.
What I was hoping for was a "known good" resonator.
cb
A xtal is more accurate than a resonator. A xtal may be something like 50PPM (0.0050 %), where a resonator is something like 0.1%. If you need extremely accurate timing a xtal is the way to go. Or maybe even a TCXO oscillator that could be 1PPM (0.0001%).
Bean.
Cool...thanks!
cbmeeks
