Sx dsp
william chan
Hi All,
Has anyone tried using the SX as a voice DSP chip?
Is the SX fast enough to sample voice sounds ( using the 2-pin AtoD method ) to store in some ram and then
play back to an amplifier ( using PWM ) ?
Thanks.
Thanks.
http://www.sxlist.com/techref/scenix/contest/52wavmmc.htm
http://www.sxlist.com/techref/scenix/lib/math/dsp/index_sx.htm
regards peter
The SX52 MMC project on sxlist.com has files .sch and .brd
What software can I use to view them?
Thanks a lot.
Alberta Printed Circuits try
http://www.apcircuits.com/resources/downloads/easytrax.zip
as found on the Alberta website.
regards peter
Greetings from Germany,
G
http://www.beyondlogic.org/pic/ringtones.htm
Not sampling audio, but playing audio from RTTTL formatted sounds (ringtones)
Although the code is in C, it is simple enough to manually translate to SX assembly or SX/B.
regards peter
