Stepper + DIRA
I'm driving a stepper with ULN2003 + DIRB (PIN4,5,6,7)
But When I added 1 more stepper to PIN0,1,2,3
Change the code as below, it doesn't work.
I've checked all the wiring andit shouldn't cause any problem. I'm thinking may be because of the binary digits. Any hints?
Cheers,
A
i VAR NIB
delay VAR BYTE
DIRA = %1111
delay = 40 'slow the step speed
cw:
FOR i = 1 TO 10
OUTA = %0011 'I/O pins 0 and 2 high
DEBUG i
PAUSE delay
OUTA = %0110 'I/O pins 0 and 3 high
DEBUG i
PAUSE delay
OUTA = %1100 'I/O pins 1 and 3 high
DEBUG i
PAUSE delay
OUTA = %1001 'I/O pins 1 and 2 high
DEBUG i
PAUSE delay
NEXT
PAUSE 2000
GOTO cw
Cheers,
A
i VAR NIB
delay VAR BYTE
DIRA = %1111
cw:
FOR i = 1 TO 10
DEBUG i
PAUSE delay
DEBUG i
PAUSE delay
DEBUG i
PAUSE delay
DEBUG i
PAUSE delay
NEXT
PAUSE 2000
GOTO cw
Jon Williams
