unexpeced pop by a newb
·I was testing a circuit on·the boe-bot·and I pulled·the ir detector back·to aim it ip·and i heard a sudden pop / explosion (no capacitor are invovled also no fire). I thought that I broke the BS2 but it was okay. Then I tested the ir detector and one "broke. The right side (place of the incident) wasnot respounding to any thing while the left side is as good as new. when I switched the sensor same thing.·what is wrong?
Did you break one of the pins on the IR?
If you just heard a 'pop', then it might have been a static discharge from your fingers to the IR.
Michael G. Jessat
Post Edited (einstiendumbness) : 6/28/2005 1:50:57 PM GMT
And no, there's no way to fix it -- but as I said, you can work around it so you don't have to replace the entire BS2 module.
And tell your mother that "The price of experience is equal to the amount of equipment ruined." It's possible to work with this stuff without breaking things -- the first principle is never do any wiring or moving of components with the power on. But no matter who you are, at some point you'll break something, it's part of learning. Really.
I'm a 20 year Electrical Engineer, who works for Nasa saying this. I've inadvertently destroyed a few things in my time. It happens.
You really should be using static dissipative tools when you're working with electronics , especially at home. Get yourself a nice static mat and handstrap for the next time you are working on your projects. Check out DIGI-KEY, section J under PROTOTYPING, TOOLS, SOLDER, TEST EQUIPMENT.
Post Edited (einstiendumbness) : 6/28/2005 5:34:49 PM GMT
