analog input with VCO? — Parallax Forums
FlyingFishFingerFlyingFishFinger Posts: 461
edited 2005-06-29 03:57 in BASIC Stamp
Hello!
I just thought of a simple way to input analog signals into the stamp: Use the analog voltage to change the frequency of a VCO (Voltage Controlled Oscillator) and then read the resulting pulses with the Stamp. Has anyone done this before? Maybe it's really stupid, just an idea of mine...would it work? I tried it with an audible 555 VCO and the pulses (read with COUNT) seemed pretty random. Should I clean them up with a Schmidt trigger ?
    edited 2005-06-28 02:16
    flyingfishfinger,
    This method is used often... instead of cleaning up your signal from the 555 with a schmidt trigger, why not base
    your oscillator around a schmidt trigger to begin with?
    Here is an interesting circuit that I have used before, that can multiplex two analog signals into one PWM signal
    that the Stamp can read.
    Use PULSIN with the "state" descriptor to get a reading from t1 or t2
    Beau Schwabe
    IC Layout Engineer
    885 x 633 - 13K
  • FlyingFishFingerFlyingFishFinger Posts: 461
    edited 2005-06-28 03:06
    In your circuit, the duration of the pulse (1 or 0) is proportional to the voltage at the input, right? But then does that mean that I have to have both inputs used to provide a referenve voltage for the other one? If I groung one, the other one would read a permanent hight, right ? ? ? The circuit looks good from my point of view though, because I'm trying to interface 2 Sharp GP2D12 sensors.
    Thanks for the moment anyway.
    edited 2005-06-28 03:24
    This circuit provides a relatively high impedance (2.2Megs) at the input. If no input were involved at all, you would have about a
    50% duty cycle on the output signal. The inputs "skew" the duty cycle in one direction or the other by about 20%, so your PWM
    ranges from 30% to 70%. Feel free to experiment with other values to get more range out of this if you want.
    Beau Schwabe
    IC Layout Engineer
    Hi!
    The circuit you suggested did not work for me (probably because of my insufficient knowledge of electronics), but I used my 555 scheme and it did work. This is no problem since I have enough breadboard space and I/O pins to spare. Thanks for your help, I consider the topic closed.
