IR Transmitting_The Next Step
This question goes along with my question concerning transmitting IR signals with the BS2. I've researched several sites suggesting transmitting via a 555 through the IR-LED. As stated earlier I have the IR codes for the RS and now I need guidance on programming. Simply how do I transmit the IR code. For instance according to the documentation the IR code to lift RS's Right Arm is $81. Could someone give an example of what the code would look like to transmit this command. My goal is to use the BS2 to program a number RS movements.
Any help is greatly appreciated.
Jon Williams
Being Google is my friend, I found this link: http://www.aibohack.com/robosap/ir_codes.htm
I can't think of a clever way to send it with a BS2 being the bit timing is ~833 uS.· It would be easy for an SX using SX/B though, in fact, with a bit of work one could create an interrupt driven transmitter that would handle sending the IR codes as well as modulating the LED(s).
Jon Williams
Post Edited (Jon Williams (Parallax)) : 6/27/2005 6:14:26 PM GMT
