Problems with a 24xx128 chip
We are having problems with the Stamp2SX chip. We have used a 24lc128 I/P from MicroChip which is recommended on parallax's site. We are getting an "EEProm Verify Failure" when downloading to the Stamp, and it only runs for about 10 seconds. By removing pins 2,3,4 and 7 on the EEprom results in a proper download of a 95% full program and 10 - 20 min runtime. Looking on Parallax's site, the parts list for the SX OEM kit lists a 24wc128 P from Catalyst. It is the same for the most part, but pins A0-A3 are listed as NC. Anyone with similar troubles or ideas on this matter your help would be greatly appreciated.
·· On the BS2sx OEM Module, pins 1 through 4 on the EEPROM are connected to ground, as is pin 7.· Pin 8 is connected to Vdd and pins 5 and 6 are the data and clock lines, respectively.
Chris Savage
Parallax Tech Support
csavage@parallax.com
·· Please send the picture to the e-mail address listed below and I will see if anything stands out.· But as per our phone conversation much of what is happening defies logic.· By letting the GND and Address lines of the EEPROM float, the device shouldn't work at all.· But you seem to be able to make the circuit work by doing that.· That is very strange indeed.
Chris Savage
