Wireless Information/Program transfer from PC to BoeBot/Basic Stamp
Hello,
········ I would like to know if there exists any module that would allow the wireless download of programs to the basic stamp from a PC. What I'm looking for is to simply replace my standard USB A to mini B cable with a wireless connection. At the very least...is there any module which will allow me to transfer data wirelessly from my BoeBot to my PC?·Any info would be·greatly appreciated.
Thank you kindly for your time
Cheers,
R.K.···
Cheers,
R.K.···
http://www.parallax.com/detail.asp?product_id=30068
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
[noparse][[/noparse]url]Http://www.parallax.com[noparse][[/noparse]/url]
What was it about the question above that caused you to recommend flexipanel as opposed to the Parallax bluetooth appmod?
Rick, I think Dave suggested the Flexipanel due to its ability to wirelessly program the basic stamp..I dont think the Parallax Bluetooth appmod can do that.
Will the Flexipanel be able to exchange data·( PC-BOE ) like the Bluetooth appmod?
Cheers!
Dave
Dave Andreae
Tech Support
One is to be able to program your BS2 on your BOEBOT remotely.
The other is to be able to talk from your BS2 on your BOEBOT to your PC.
I'm not sure you can do both at the same time -- and which one you really want is not clear.
····· Well I honestly didn't think I was asking for 2 very different things here...what I am looking for is something to replace the USB A to mini B cable I currently use to communicate / program my Boebot. So, could I use the flexipanel to remotely program my robot and the blue tooth appmod for serin/serout communication? I was probably not clear as to what I meant by communication..but serin/serout would do the trick
Cheers!
R.K.
I have a dumb question; is the FlexiPanel something you can put on the BOE and then be able to remotely program the BS2? The description on Parallax's site said something about "remote FlexiPanel operator interface" What is that? Could it be a PC (as the interface) with some sort of transmitter (via USB???) It would be great to not have to plug the BOE into the copmuter for every little change!
Thanks!
Robotics
ro-bot-ics (noun)
the science or technology of robots, their design, manufacture, application, use, etc.
Post Edited (pcrobot) : 6/23/2005 11:33:36 PM GMT
·· The LinkMatik SE from www.flexipanel.com can program the Stamp wirelessly.· Please see their website for details.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Ryan
Chris Savage
I'm going to e-mail FlexiPanel and ask for more info.
But, it looks like you have to buy the FlexiPanel (to go on the BOE) and the LinkMatik SE (Stamp programmer) Programming Cable (to go on the computer???)
I let you all know what I find out...
Robotics
ro-bot-ics (noun)
·· Try this link...· http://www.flexipanel.com/LinkMatikSE/index.htm·
Chris Savage
I'm currently searching the wireless devices which will be replaces the RS232 cable:
LinkMatik SE Product
As i understand from the Flexipanel company, the product for the LinkMatik SE Product is basicllly used
Stamp WFP.exe to program the Basic Stamp (BS2) ·by pressing the run button after written the BASIC code in the BASIC code editor V2.1
EmbeddedBlue Transceiver AppMod (Eb500)
If i chose this product, can i continue to write and program using BASIC code editor V2.1 without using other software
My requirements for selecting the right wireless devices
I just·need a Wireless device which basically·just to replace the RS232 cable. However there is not additional software involves cos i want to make it·as simple as possible. I'm currently create·a GUI in Visual Basic v6.0·which link to the Basic Stamp.
So in the GUi Visual Basic which few action buttons (e.g.Forward, backward, etc), the user is able to click the any icon they want for the robot to move.
So can this EmbeddedBlue Transceiver AppMod (Eb500) be able to suit my requirement?
New1976
http://www.electrowave.com/products/stamper.shtml
It's me.
······ I'm also looking into creating a GUI in VB6.0 I'm new to VB and not sure how communicating via the basic stamp works. Could you provide a bit of sample code or any resources on how to go about doing this?
Cheers,
R.K.
See the Attachment.
One way is to Download a program to BStamp connected with PC and the boebot execute accordingly by communicating thru RF . But this makes the data fixed.
Is there any way out to send LIVE (REAL TIME )data or command to the BOE connected to the PC so that when sent thru RF the BOEBOT executes.
The Stamp on the BOE and the Stamp on the BOEBOT need to understand a shared, common "language" that you will have to develop. By "language" I mean a command set that will enable the BOE to command the BOEBOT to perform certain tasks. Below is a simplified command set, just as an example:
verb modifier one modifier two
M(ove) direction amount or distance
Ex. M, F, 10; verbalized: move forward 10 units
T(urn) direction amount
Ex. T, R, 90; verbalized: Turn right 90 degrees
S(top) none none
Ex. S; verbalized: halt all action
P(ause) time units none
Ex. P, 1000; verbalized: pause for 1000 milliseconds (or some other unit of time)
You will need one command for each discrete action you want the BOEBOT to be able to take. It would probably be wise to send each command string more than once. If the first and second command transmissions are the same, then the command can be executed, otherwise a re-transmission is requested. The design and content of the "language" is wholly up to you, and there is no standard for such a control language that I know of.
I hope that gets you started.
Bruce Bates
Nice explanation.......thanks...... this i'll implement in later stage.
Present problem is
i want to send commands & receive datas from the boebot or controll it.
The BOE connected to PC with RF Transceiver
We have to download the codes to the BStamp,, whatever we write in our coding that remain fixed. there is no way to instruct thru keyboard i.e. live communication / control in users hand.
It is difficult to obtain this from the basic stamp debugger. DEBUGIN command is there but wont serve much. Nor we can save the datas sent by the boebot to BOE.
Please suggest
Again, I'm not sure what you're trying to accomplish, but if I wanted to communicate between two Stamps, I'd use SEROUT and SERIN, with the baudmodes set the same. Once the data is read in with SERIN, you can do whatever you want to with it. I'd get the entire system working in totally wired mode (tether), and THEN as phase two add the wireless link.
DEBUGIN is usually used for small amounts of data and/or infrequent data transmissions. SERIN and SEROUT are far more robust commands with a greater number of user options.
I'm presuming your setup looks something like this:
Stamp on
PC--wired link-->BOE Board--wired link<<--RF Transciever-->>
<<---wireless link---->>
Stamp on
<<--RF Transceiver-->>wired link---BOEBOT
Bruce Bates
