why is pulsout so far out
I have been using the pulsout command to drive servos As one would, But I have failed to understand why if I·use a scope on the command that the scope shows me a value far less than the calucated pulse width that I ment to use.
Other BS2 variants (BS2sx, BS2p) have different 'Tick' sizes.
Otherwise, I don't know why the pulse widths would vary -- what are the numbers you're finding? (In other words, you would say, "I set it to 750, but I see a 1 mSec pulse, which is far less than the 1.5 mSec pulse I would expect.")
Those are the kind of questions we can answer more accurately. Are your servo's working, by the way?
Which Stamp module are you using? What is the value in your PULSOUT statement? What are you seeing on your 'scope?
Jon Williams
·· Perhaps there is something wrong with the scope?· PAUSE 20 should give a delay of 20mS, not 17-18.8uS.· And if the scope has two triggers, what is triggering the channel you're reading, what level is the trigger and is it rising or falling edge triggered?
Chris Savage
Parallax Tech Support
csavage@parallax.com
·· Your picture did not come out.· Remember that JPG and GIF are universal formats, PSD is not.
Chris Savage
·this the reading that the scope gives at pulsout 1300.
·· I would try some other settings on your scope.· The whole waveform isn't even being shown.· What resolution do you have the scope set to?
Chris Savage
Hopfully this on will be easier to read,· the pause is 20ms
David
·· Again, I must say it must be something with your scope, as here's a screenshot from mine, and it all looks fine on a BS2p, with the following code.
' {$STAMP BS2p} ' {$PBASIC 2.5} DO PULSOUT 15, 1300 PAUSE 20 LOOP▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Chris Savage
Chris Savage
Jon Williams
·· Yeah, it's got to be something with his scope...Ol' Faithful (Parallax USB O'Scope) tells it like it is!·
Chris Savage
your scope is it 8 bit 12bit 16 bit or 32 bit. I ask because the results will vary greatly between the three different types of scopes. I have used my scope in past to calabrate a Spectro scope, then compared the calabration with the calabration book suppied with the spectro scope.
PERFECT RESULT
As always you hit the nail on the head. Problem solved I haven't done my math properly
·· I think the scope information is irrelevant.· If I connect our Tektronix TDS 1012 here at Parallax I get the same results.· The point is, you didn't answer the question, which is, what is the problem you are having with the BS2p that prompted you to investigate the timing?· Perhaps there is a code error or something else.
Chris Savage
The 8 bit to 16 bit scope, started with the blind leading the blind ( His scope must be wrong)
The answer I was looking for was( 1300 * 0.8= ?) Problem solved, it was my mistake.
Post Edited By Moderator (Chris Savage (Parallax)) : 6/25/2005 9:28:19 PM GMT
