Connection Problems!
Hello everyone,
I have a basic stamp2 homework board. It works fine on my laptop with a built-in serial port. But on my new laptop I am have no serial port, just USBs. I bought a Belkin USB to serial port adapter. The adapter works find with any other serial·device but does not work with the stamp2 homework board.
When I check Identify it says a BS2pe exists on COM2. When I go to download a program it fails with a "Hardware Communication Error!." I have tried switching ports, UART on/off, UART high speed/low speed and every other setting you could imagine.
I already have a running program from when I was using my other laptop. I see the red R light on the adapter going on and off as it should and when I goto the debug screen I see in3 = 0 as I should be.
Also when I hit a key in the debug window the TX light on my adapter goes on and off as it should so it seems like I am getting a connection both in and out.
I just don't get it. Any help would be appreciated.
Stede
Post Edited (stedetro) : 6/20/2005 1:46:08 AM GMT
Stede
The Belkin cable probably doesn't support the break condition in RS-232, so it will not work. There are many threads on this forum about serial to USB adapters. And this thread will probably quickly grow like the rest of them. Your problem could like with the hardware or drivers, but you'll never know for certain unless you put a scope on the serial output and compare the signals to the ones which are supposed to be present.
Historically, people owning adapters have either decided to get one that works or to fight with the one they have already purchased. I suggest you take it back to where you bought it, and get one that works. For example:
FTDI USB to Serial Adapter
This one will work for certain with all of our products.
RadioShack's USB to Serial adapter also works if you don't want to wait for ours. Theirs is $41.99 and available in most stores. Go to www.radioshack.com and check their inventory at a store near you.
Is this a Windows problem or a Belkin problem?
I guess even serial ports are not standard anymore.
thanks again,
Stede
Jon Williams
Thanks for your help,
Stede
FTDI and Keyspan seem to have taken no short-cuts, and thus they are good replacements for a missing motherboard serial port. It's really not Parallax'es fault -- they can't control what other vendors do, and their use of the RS-232 port and handshake signals is completely standard.
http://www.hvwtech.com/pages/products_view.asp?ProductID=524
You may have another problem...
Possibly the FIFO settings for the COM port?
Check THIS thread.
Don't visit my new website...
