7219 shifting
hi
got the 7219 working!!! but am having a funny problem where the data is shifting (sometimes) one column to the right.
Is there a bit of buggy code, or could it be a power problem.
Here's the code, adapted from the Nuts n Volts article:
also, what is the theory around cascading/daisy chaining the 7219s. how do you get date onto say a second 7219
thanks
george
' ----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
Clock CON 0 ' shift clock to MAX7219
DPin CON 1 ' shift data to MAX7219
Load CON 2 '
' ----[noparse][[/noparse] Constants ]-------------------------------------------------------
Decode CON $09 ' bcd decode
'Decode CON $00
Intensity CON $0A ' brightness
Scan CON $0B ' scan (column) limit
ShutDn CON $0C ' shutdown (1 = on)
Test CON $0F ' display test mode
Yes CON 1
No CON 0
' ----[noparse][[/noparse] Variables ]-------------------------------------------------------
index VAR NIB ' loop counter
idxOdd VAR index.BIT0 ' is index odd? (1 = yes)
d7219 VAR BYTE ' data for MAX7219
char VAR BYTE ' character ee address
col VAR NIB ' column value
row VAR NIB ' row value
eeAddr1 VAR BYTE ' ee pointer
eeAddr2 VAR BYTE
vScroll VAR WORD ' scrolling data buffer
' ----[noparse][[/noparse] EEPROM Data ]-----------------------------------------------------
Char_B DATA %11111111 ' xxxxxxx
DATA %10111111 ' x..x..x
DATA %11111111 ' x..x..x
DATA %11111111 ' .xx.xx.
DATA 0
Char_S DATA %01010101 ' .x..xx.
DATA %10101011 ' x..x..x
DATA %01010101 ' x..x..x
DATA %01010101 ' .xx..x.
DATA %10101011 ' .xx.xx.
DATA %01010101 ' .xx.xx.
' DATA 0
Char_2 DATA %10101010 ' x..x..x
DATA %11010101 ' x..x..x
DATA %11010101 ' .xx..x.
DATA %10101010 ' .xx.xx.
DATA %11010101 ' .xx.xx.
DATA %11010101 ' .x..xx.
Char_3 DATA %00011000 ' x..x..x
DATA %00111100 ' x..x..x
DATA %01111110 ' x..x..x
DATA %11011011 ' .xx..x.
DATA %01011010 ' .xx.xx.
DATA %10000001 ' .xx.xx.
DATA %01000010 ' .x..xx.
' ----[noparse][[/noparse] Initialization ]--------------------------------------------------
Initialize:
DIRL = %111 ' clock, data and load pins
FOR index = 0 TO 5 ' six addresses & values (from 0 to 5)
LOOKUP index,[noparse][[/noparse]Scan,7,Intensity,7,Shutdn,1],d7219 ' those values stored in VAR d7219 one by one
SHIFTOUT Dpin,Clock,MSBFIRST,[noparse][[/noparse]d7219] ' ... and sent to 7219 when pulsed
IF idxOdd = No THEN NoLoad ' not a clue what this does
PULSOUT Load,3 ' pulsed here (sent to 7219)
NoLoad:
'DEBUG ? d7219
NEXT
' ----[noparse][[/noparse] Main Code ]-------------------------------------------------------
Main:
Flash_Characters: ' on screen, one at a time
FOR char = 0 TO 3
LOOKUP char,[noparse][[/noparse]Char_B,Char_S,Char_2,Char_3],eeAddr1
GOSUB ShowChar
PAUSE 2000
NEXT
GOTO Main
' ----[noparse][[/noparse] Subroutines ]-----------------------------------------------------
ShowChar:
FOR col = 1 TO 8 ' character is 8 columns wide
READ (eeAddr1 + col - 1),d7219 ' read column data fromEEPROM
SHIFTOUT Dpin,Clock,MSBFIRST,[noparse][[/noparse]col,d7219]
PULSOUT Load,3
PAUSE 50
NEXT
RETURN
thanks
george
http://pdfserv.maxim-ic.com/en/ds/MAX7219-MAX7221.pdf
I think all you need to do is shiftout the right number of bits and then kick the load9/CS) line. Think of them as serially cascaded shift registers.
I don't see anything overtly wrong with the code, but I don't have time to do more than glance at it right now. Hopefully someone else can give it a more in-depth look.
My $0.02
-dave
This is not a sig. This is a duck. Quack.
