BS2 freezing
I have an unpredictable behavior by a BS2 that activates a motor via a solid state relay.· the user activates the motor by pushing a button.· the motor moves an object a distance of about 5 feet and then is stopped by a magnetic switch.· The stamp controlls all this and it works very well.
but a weird things started happening, every 200 - 300 cycles of motor on / off the stamp freezes and will not operate normally until the power is turned off and then back on.
Is there a obvious diagnostic for such problems?· Does the stamp has a reputation for unpredictably freezing like I am describing above?
hope to get some insights...
Al
Al
Jon Williams
Al
I don't know how you are powering your solid-state relay, but some more capacitance there might help.
Motor noise spikes on AC or DC lines can be unpredictable and cause the side-effects you are seeing.
Appropriately sized (in voltage and capacitance) capacitors, appropriately positioned (across Vdd and Vss, across the motor power leads, and perhaps across the SSR)·can reduce this.
Many thanks
Al
