How to choose a good servo?
Hi
I'm starting about this, and I don't have experience with motors, I need to know how to choose the correct motor to a robotic arm, I need an amplifier?, I think so, but i don't know none of Parallax, I don't know what amplifier circuit. I realy thank something like a link to a device!. Is that, I'd like to show this machine in class, I have the arm and all but "In what I must base, what i have to consider?.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
[noparse][[/noparse]url]Http://www.parallax.com[noparse][[/noparse]/url]
Post Edited (Dave Andreae (Parallax)) : 6/11/2005 3:15:34 PM GMT
1. How much torque is needed on the 'joint' to move it? A common servo (Futaba 148) will produce 44 inch-oz of torque.
2. How long is the arm, and how heavy is the arm. Affects the amount of torque.
3. How much weight should the arm pick up? Again, affects the amount of torque.
4. How will you mount the motor?
5. How will you detect the arm position? Servo's are good for this, as they have good repeatable positioning. They use internal feedback for this, so your BS2 doesn't have to read a position.
6. How many joints do you have? This affects the number of servos you need. This is sometimes called 'degrees of freedom'.
Hi Allanlane5
I tell you, for example, if i've got an robotic arm with 5 axis to place motors that weights 1,3kgs without servos, almost 2kgs with this, and I'd like to pick up with this 3kgs, i must choose a servo with more torque than the weight of the arm loaded (5kgs)?. What happen if i use a motor with inferior or the same force?. OK thanks
Carlos
Also, a "Servo" is a neat device for $20 or so which contains a motor, some reduction gears, a comparitor circuit, and a variable resistor connected to the gears. It is not itself a 'Motor', though it can be used in a robot drive train. It is particularly easy for a BS2 to control through the "PULSOUT" command.
A 'motor' is typically a small device which you put +5 volts on the 'hot' lead, ground on the 'neutral', and it spins. A much more primitive device. To run it with a BS2 takes an 'H-Bridge', which allows the BS2 to switch on +5 and ground in both directions. Then you want speed control. This requires a "Pulse-Width-Modulated" signal (basically, switching power on and off quickly) to control the speed.
Then, there are "stepper motors". These have multiple windings. Each time you power one set of windings, the motor 'jumps' forward a little bit. Then you power the next set of windings to take the next 'step'. Keep powering set after set after set, and the motor continues to rotate.
So, to summarize: The PSC is an external board that lets you control multiple Servo's -- ONLY servo's.
A 'Motor' requires an H-Bridge and a PWM circuit -- typically these are combined in to a 'motor controller board'.
A 'Stepper' -- well, I think you can control a stepper with a few transistors.
And if your motor or servo does not have enough torque, it can't move the load.
Yes, a BASIC Stamp 2 and a PSC will allow to control your robotic arm with the proper servos as Alan has pointed out.· Parallax's standard servo is the Futaba· S-148.
Dave
Dave Andreae
Tech Support
I guess that to buy a 'servo' is better, yeahh. If "I connect the BS2 with PSC 'by means of the protoboard' to control a Servo with enough torque", say me please, Can I connect directly the BS2 module to computer or to a home power supply and it will not damage the servos or circuits?. Then, when I'm using the circuits without the computer, I must use a battery between 5 and 7V, no more truth?, OK ^_^, now I will try to construct this on this way. But I believe to begin I prefer to cut more aluminium and to model more acrylic putty and glass fiber to make a robotic leg. I'm watching that i need two servos only, a strong one and a more weak one, if everything comes out right, i will show you it.
Carlos.
If you're just experimenting, you can absolutely build things light, use any decent servo and if it doesn't lift the weight of the mechanism itself, get a more powerful servo, but an understanding of the variables your working with is here in a mix of scientific and layperson's language.
This becomes much more important if you're trying to design the machine for a specific application (i.e. pick up a soda can).
http://www.solarbotics.net/bftgu/tutorials_mech_torque.html
