Controlling 120 VAC lights with a Stamp
Dimming lights with a Stamp is relatively easy.· With the help of some additional circuitry, it is possible for the Stamp to perform some very fun feats of lighting control. The nice feature of this circuit is that it is easily expandable and provides very fine (225 useful steps) control over the light level.
Background
I was looking for some method of controlling the lighting in Halloween haunted house dioramas.· I found an article titled “All-digital circuit fires triac” that appeared in the July 21, 1994 issue of “Electronic Design News”, and can be seen at the link below.
http://www.edn.com/archives/1994/072194/graphs/15di3fg1.htm
I made some minor additions to the circuit and one change to the timing as shown in the original article.· This circuit works dependably and is great for setting the mood of an event.
Possible uses for this circuit
Animated holiday light displays
Party lighting
Halloween haunting, lightning effects
Strobe effects
AC sine wave
In the USA, single-phase alternating current has a frequency of 60 cycles per second.· The voltage curve varies from zero up to +150 volts and back to zero volts and then to -150 volts and returns to zero volts.· The curves are sinusoidal, not circular.· The root-mean-square (RMS) of all points on either curve equals 120 volts.· However, for this circuit, being aware of the voltage at various points in the sine wave is important.
General Description
The light dimmer circuit consists of 3 functional blocks: timing, control, and 120 VAC switching.· The objectives of the dimmer circuit are:
1.················· To be able to pick any point in the positive or negative AC half-wave to switch the current on,
2.················· To repeat turn-on at this point indefinitely until a new turn-on point is selected.
3.················· To electrically isolate the 120 VAC portion of the circuit from the rest of the circuit.
120 VAC Devices and AC switching
Triac
The triac is the device that will switch the AC. The terminals on a triac are labeled Main Terminal 1 (MT1), Main Terminal 2 (MT2) and the Gate (G).
From a black box perspective, the triac has four important functional characteristics (assuming the device is operating within its maximum ratings):
1.········ The triac will conduct in either direction of current flow. This means that current can flow from MT1 to MT2 or from MT2 to MT1.
2.········ The triac will only begin conducting when triggered by a current applied to the Gate.·
3.········ The triac automatically ceases conducting when (only if) the voltage across and current through MT1 and MT2 goes to zero, after which the triac must be re-triggered to begin conducting again.
4.········ Once triggered, the triac will continue conducting until the next zero voltage crossing point in the AC sine wave regardless of the voltage/current applied to the gate. So, once triggered, the Gate input is in a “don’t care” state until after the next zero crossing point.
To summarize, the triac will only begin conducting when triggered and will continue conducting regardless of the state of the gate until the next zero voltage crossing point. The triac can be triggered in either the positive or negative part of the AC sine wave.
A helpful article titled “Thyristors and triacs - Ten golden rules for success in your application” can be found here:
http://www.web-ee.com/primers/files/AN_Golden_rules.pdf&e=7620
Triac Trigger (MOC3010M)
The triac trigger is a device that provides 5 V inputs to an internal LED (through a suitable current-limiting resistor) on one side and a 120 VAC optically triggered triac on the other side.· This device electrically isolates the 120 VAC side of the circuit from the logic level side of the circuit. Using a triac to trigger the main triac solves the problem of triggering the main triac on the positive or negative voltage portion of the AC sine wave.
Zero Crossing detector (H11AA1)
This device provides notification of when the AC voltage is zero.· It consists of two cross-coupled LEDs on the AC side and a phototransistor on the logic level side.· Thus the one or the other LEDs is on during any non-zero portion of the AC sine wave. ·Both LEDs are off at the zero voltage point. By adding a 10K pull-up resistor to the photo transistor output on the logic level side of the device, the zero crossing detector will pull the output low during the non-zero portion of the sine wave and the 10 K resistor will pull the line up to 5 V when the photo transistor turns off.· The zero crossing detector will produce a positive going pulse every 8.333 milliseconds (1/120 =· .0083333).· This device electrically isolates the 120 VAC side of the circuit from the logic level side of the circuit.
Simple 1-channel circuit (Attachment 1)
This simple 1-channel circuit can be built using a Stamp for control and timing.· In this configuration, the Stamp has one pin connected to the trigger input of the triac trigger and one pin connected to the zero cross line. The Stamp must poll the zero crossing clock line and when the zero cross line goes high, initiate the change to the triac.· This circuit is not practical for dimming because retriggering the triac at a specific point in the sine wave will totally consume the Stamp and leave no time left for other computing.· The circuit will function adequately to turn the triac full-on or full-off.· The following sample code will blink a lamp at 1 second intervals:
Trigger············· PIN·········· 0
ZeroCross······ ··PIN·········· 1
Main:
DO
· GOSUB··········· TriacOn
· PAUSE············ 1000
· GOSUB··········· TriacOff
LOOP
‘·········· [noparse][[/noparse]Subroutines]
TriacOn:
DO WHILE (ZeroCross = 0)
LOOP
HIGH Trigger
RETURN
TriacOff:
LOOP
LOW Trigger
RETURN
This circuit does not meet the requirement of being able to trigger the triac at any point in the AC half-cycle and repeatedly turn it on at this point, but does implement simple on-off control.
Circuit component costs:
Triac-4Amps······················ $1.87
Heatsink·························· 1.00
MOC3010M triac trigger············ 0.86
H11AA1 zero cross detector······· ·0.42
4 ¼ watt resistors··············· ·0.20
Total·····························$4.35
Fully functional 1-channel dimmer (Attachment 2)
This circuit offloads all timing and control from the Stamp to external circuitry.· By adding a 1MHz TTL crystal and a 14-bit ripple counter with reset, the timing issues are solved.· By adding a comparator that compares two 8-bit terms labeled P and Q and provides a low output when P>Q, the control problem is solved.
The 1 MHz crystal output is fed directly into the ripple counter.· The ripple counter is free-running. The first 5 stages (bits 0 through 4) of the ripple counter are not used.· The next 8 output stages (bits 6 through 13) of the counter are the term P fed into the comparator. The first 5 stages of the ripple counter serve to divide the crystal clock rate by 32.· This results in a clock rate of 31,250 Hz fed into the next 8-bit counter stage that makes up the P term. Since the ripple counter’s reset pin is connected to the zero cross line, the counter is reset every 120th of a second. There are 260 clock pulses (31,250 / 120 = 260) going into the 8-bit counter stages that make up the P term. Thus the 8-bit P term counts from 0 to 255, rolls over to zero and continues counting ·to 4, when it is reset to zero by the zero cross line.· This repeats for each AC half wave.· The counter roll over slop does not affect the performance of the circuit, since the triac is likely already triggered by this point in the cycle, and any changes on the triac trigger are ignored until the triac resets itself at the next zero crossing point.
The 8-bit output of the counter is connected to the P inputs of the comparator.· Pins 0 through 7 of the Stamp are connected to the Q inputs of the comparator.· When the count value on the P inputs is greater than the trigger value on the Q inputs, the triac trigger line is driven low, which fires the triac.
So by manipulating the trigger value with the Stamp, you can control the trigger point in the AC half-wave, and this circuit will continually retrigger the triac at this point until the trigger value is changed.
In order for the Stamp to know when to change the Q value, it must poll the zero cross line and only change the Q inputs when the zero cross line is high.· Otherwise, changes in Q inputs can occur in mid AC cycle, resulting in lamp flicker.
Notice that the trigger values are reversed from what one might intuitively expect.· For example, a trigger value of zero is full-on, while a trigger value of 255 is full-off. This is because the triggering condition occurs when the counter value exceeds the trigger value. So if the trigger value is zero, when the counter value reaches 1, the counter value is greater than the trigger value and the triac is triggered.· Conversely, if the trigger value is 255, the count never is greater than 255 and the triac is not triggered.
The following subroutines can be used to implement this dimmer circuit.
TrigValue········ VAR··· Byte···························· ‘Trigger value
ZeroCross······· PIN···· 8································· ‘Pin attached to zero cross line
Main:
‘·········· This loop will ramp the light on in 225 steps - notice that the count proceeds from 225 to 0
FOR TrigValue = 225 to 0
· GOSUB SendTriac
· PAUSE 100
NEXT
END
SendTriac:
LOOP
OUTL = TrigValue
RETURN
The terminal count of 225 is simply the number that represents the last value for which I could observe filament illumination.· So, even though values greater than 225 do indeed turn the triac on during the down-slope of the sine wave, the voltage at that point is insufficient to illuminate a lamp filament.· Thus I reduced the maximum trigger value to 225.· At 225 no visible light is produced, but at any value less than 225 the filament will glow.
Triac-4Amps······· ···················· ·$1.87
Heatsink································ ·1.00
MOC3010M triac trigger·············· ·0.86
H11AA1 zero cross detector·········· ·0.42
4 ¼ watt resistors·················· ·0.20
1Mhz TTL crystal···················· ·1.70
CD4020N 14-bit ripple counter········ 0.60
74LS682 8-bit magnitude comparator··· 1.10
Total······························ ·$7.75
This circuit works fine but uses a lot of precious stamp pins.· The next circuit adds two additional devices to reduce the number of Stamp pins needed.
Fully functional 1-channel dimmer that uses only three Stamp pins (Attachment 3)
This circuit adds a serial to parallel shift register and an 8-bit latch.· This relieves the Stamp of presenting the 8-bit trigger value on eight of its own pins and offloads the zero cross line polling.· The stamp can send the 8-bit trigger value serially.· The serial to parallel shift register will present the 8-bit trigger value to the 8-bit parallel latch.· The latch is used to control the timing of when the trigger value is presented to the comparator, which must by synchronous with the zero cross line to avoid flicker.
SerialClock················· PIN····· 0····················· ‘Serial transmission clock line
SerialData··················· PIN····· 1····················· ‘Serial data line
TriacLatchEnable········· PIN····· 2····················· ‘8-bit latch enable pin
TriacTriggerValue········ VAR··· BYTE············· ‘byte for holding trigger value
Main:
‘·········· Ramp the light on
LOW·· TriacLatchEnable································· ‘initialize state of latch enable pin
FOR TriacTriggerValue = 225 to 0
· GOSUB SendTriac
NEXT
END
SendTriac:
SHIFTOUT· SerialClock, SerialData, MSBFIRST, TriacTriggerValue· ‘Send data to shift register
PULSOUT· TriacLatchEnable, 5000············· ··································· ‘hold pulse for 10 mSecs
RETURN
This circuit is simple to program and uses only three Stamp pins.· It is a fully synchronous circuit and will provide flicker free operation.
Triac-4Amps···················· ········ $1.87
Heatsink···················· ··· ········ 1.00
H11AA1 zero cross detector··········· 0.42
4 ¼ watt resistors··················· 0.20
1Mhz TTL crystal····················· 1.70
74LS164 Serial-to-parallel
·shift register······················ 0.45
74LS377 Octal D register············· 0.70
Total······························· $9.10
Eight-channel light dimmer (Attachment 4)
By adding a 3-line to 8-line decoder and three more Stamp pins for addressing, the circuit can be expanded to an eight channel dimmer. The serial-to-parallel shift register is connected to all 8-bit latches.· The three address bits are used to select the specific 8-bit latch to store the trigger value. The following code will drive this circuit.
TriacAddr··················· VAR··· Nib····························· ‘Triac latch address (0 through 7)
TriacAddr0················· VAR··· TriacAddr.Bit0
TriacAddr1················· VAR··· TriacAddr.Bit1
TriacAddr2················· VAR··· TriacAddr.Bit2
TriacPin0····················· PIN····· 0································· ‘Triac addr pin 0
TriacPin1····················· PIN····· 1
TriacPin2····················· PIN····· 2
TriacLatchEnable········· PIN······3····················· ‘8-bit latch enable pin
Main:
‘·········· Ramp all lights on
HIGH· TriacLatchEnable
· ·FOR TriacAddr = 0 to 7
···· ··GOSUB SendTriac
· ·NEXT
NEXT
END··
SendTriac:
‘ ········· Send data to shift register
‘·········· Set up address of latch
TriacPin0 = TriacAddr0
TriacPin1 = TriacAddr1
TriacPin2 = TriacAddr2
‘·········· Latch the data
PULSOUT· TriacLatchEnable, 5000············· ‘hold pulse for 10 mSecs
RETURN
Triac-4Amps······························$1.87
Heatsink···················· ··········· ·1.00
·shift register····················· ·0.45
74LS377 8-bit latch ················ ·0.70
74LS155 Dual 1 line to four line
·Data distributor··················· ·0.35
Total······························ ·$9.25
This final version of the circuit is the best, because of the number of channels supported.· Each additional channel requires addition of:
Triac with heat sink··············· ·$2.87
MOC3030M triac trigger,············· ·0.86
2 ¼ watt resistors··············· ··· 0.10
74LS377 8-bit latch·············· ··· 0.70
Incremental cost of each channel·····$5.63
I used Teccor triacs.· These are available with isolated tabs in a TO-220 style case. This keeps the AC off of the Heatsink.· Current ratings range from 4 to 15 Amps.· All can be triggered with the MOC3010M triac trigger.· Review the manufacturer’s data sheet regarding heat sink requirements.
Attachment 5 is a collection of Parallax USB Oscilloscope images of the zero cross detector output· (blue) and the triac trigger line (red).· The images show the following cases: Full off, ¼ on, ¾ on and full on. Each image shows the activity in one-half of the AC sine wave, the period between zero crossing events.
Final notes
This circuit can ONLY be used for dimming lights.· Inductive loads cannot be used.· This includes electric motors and fluorescent lamp ballasts. The reason is that the reverse EMF produced by inductive loads produces an out-of-phase wave back to the triac so that the triac never sees zero volts.· Thus the triac never ceases conducting, resulting in total loss of control.· There are snubber circuits that can be added to filter this reverse EMF and restore order to the triac.
As with all circuits that use 120 volt AC mains, the circuit should properly fused for the loads to be used.· Due care must be taken when working AC Mains voltage to protect from shock and injury.· Never work on the circuit with Mains voltage applied to the circuit.· Do not bring Mains voltage onto a breadboard.· It is too easy to forget where on the breadboard these voltages are.·
You can put the AC side of the circuit on a perfboard or prototype board and bring the logic level signals to/from a breadboard.· Just remember to use adequately sized wire in the AC side for the anticipated current.
Corrections:
Changed Attachment 4 to correct address and data inputs on device 74LS155 (had them reversed) and changed polarity on Latch_Enable line from LOW at rest to HIGH at rest.· This is an active LOW signal.·PULSOUT will invert the output state of the pin for the specified time and then restore to its original state.
Post Edited (RTurley) : 2/9/2005 1:30:49 PM GMT
Background
Party lighting
Strobe effects
AC sine wave
General Description
Triac
Main:
DO
LOOP
TriacOn:
LOOP
HIGH Trigger
RETURN
TriacOff:
LOOP
LOW Trigger
RETURN
Main:
· GOSUB SendTriac
· PAUSE 100
NEXT
END
SendTriac:
LOOP
OUTL = TrigValue
RETURN
Main:
· GOSUB SendTriac
NEXT
END
SendTriac:
RETURN
Main:
· ·NEXT
NEXT
END··
SendTriac:
RETURN
Final notes
Corrections:
bugg
So many projects, so little time.
Thanks again.
ps are you interested in getting paid to make a few setups for me?· I am not an electronics whiz and can already see when I went to Jameco that with the part· number it gives me choices and I am am unsure of what to order
If you decide to build some for briano, sign me up as well.
Starman
Imagine if someone's house burns down because your circuit failed...
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
·· Each time the AC voltage crosses zero volts, the triac stops conducting and needs to be re-triggered.· If this is done at points other than the zero-crossing point, it generates more electrical noise for the device.
Chris Savage
Parallax Tech Support
csavage@parallax.com
If your just simply turning on or off then you only get noise from the "one" half cycle that you turned it on and then from then on the triac is retriggered on the zero crossing since the triac will·be gated ON·already for every half cycle that comes·before you want to·turn OFF·power·(or am I wrong about this?).
Todd Snyder
·· Perhaps I missed something somewhere.· If you're turning the light on, then the TRIAC continually needs to be re-triggered.· Triggering based on the Zero-Crossing point shouldn't affect the first cycle as opposed to all subsequent cycles.· I guess I don't see the correlation/point of the first cycle being triggered differently.
Chris Savage
Like I say, I'll go reread the method posted...from your reply I guess the stamp has to revisit the triac to turn it back on·at every zero crossing.
·· I wasn't referring to the Stamp, but rather the Triac being re-triggered, which is where we may be on a different view of this.· I just looked at the circuit, and it appears to be using an existing AC signal as a reference for clocking the TRIAC output.· Obviously there is more involved here, but my comment was based on there being a difference in the point during the cycle in which the triac if triggered being different on the first activation.
·· In any event, this is a nice circuit design...Not too many parts, considering what it's doing.· Could easily be adpated into a module form for easy connection to the BASIC Stamp.· As for the parallel interface, that could also be handled with a 74HC595 requiring only 3 pins to talk to the device instead of 8.
Chris Savage
This is true, but the software should be turning on the light _after_ the zero crossing point. A triac will turn off the load at zero crossing. The stamp can turn _on_ the load at any point, but the load will only go _off_ at zero (very close to it anyway).
To achieve a fade, you need to monitor "zero crossing" via a detector,
start counting, and "pulse" on the load after some determined time.
The longer the time, the shorter the "on time" before zero crossing,
and the dimmer the light.
If you do not use a zero crossing detector, you wont know when to "turn on" the load and you will get a pretty eratic flicker instead of a nice fade.
Note: these circuits are pretty noisey by nature. Commonly an inductance filter is put inline with the load to reduce the naiose on the line.
jumblo
I·would love to see an external serially·programmed·device that offloads the hard work.· The prop-1 could send out the fade command, and·let the device do the work.
A simpler request is for an external fader that you send a simple on/off signal to.· The fade could be prewired, or adjustable via a pot.· For many of my applications, I just want a simple fade and have no need to adjust the rate once the prop is set up.· Any lines on such a device?
jumblo
I have been usisng some very slow fades (~30s) with
this design, and have not noticed any steps (except the
one from very dim to full off). Were you using large-wattage
lights when you saw this effect? Just curious....
croussi
Terry
Excellent - projects/ideas
Good Job !
L Sutherland
This is a very nice Project
The reason·I am asking is because·
I want One Basic Stamp and One Dimmer Circuit·as a·Stand Lone
·I want to make 3 or 4 of them
Are you going to make a circuit board for your project if so
Please let me know
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 10/31/2007 9:37:53 PM GMT
The original post was 2005, has a new best practice emerged for variable control of an AC load since then?
Patrick
